I keep reading this thread over beginning to end and believe I'm starting to see what may be happening. First, an assumption on my part is that Acu-rite uses the barometric readings (at least) to generate the forecast icons regardless of what's actually happening outside at the present or near future. Similar to the old forecast saying, dropping pressure=stormy weather approaching, rising pressure=expect clearing, etc. Other wx stations use the barometer this way for their forecast icons too. Certain times of the year here I see my stations doing this, show cloudy and/or rain and there isn't a cloud around. This was because the pressure took a dive. During our rainy/monsoon season this works pretty accurately but during our 5-6 month dry season I ignore it. So, if this is the case I'd recommend just ignoring the forecast portion for now and concentrate on your actual barometric readings. Compare every couple waking hours to your local wx radio/tv station's barometric readings. You may find out that yours is actually tracking correctly with the nightly drops and daily rises. Or even watch the station you compare to a mile away, even if you are "20 points" different do you both rise and fall the same?
