Author Topic: Is it back up?  (Read 4201 times)
Offline sho23
  • KN6DZN
    • LinkedIn
Is it back up?
« on: January 08, 2018, 12:39:22 PM »
I noticed that WU is mostly back up, but my data is very spotty and it says the station is nor reporting (it's reporting fine in weatherlink site and in cwop's findu)
So .. is WU just trying to get back to normal, or do I need further troubleshooting on my reporting pathway somehow?
Offline Catskin
Re: Is it back up?
« Reply #1 on: January 08, 2018, 03:45:41 PM »
mine is doing the same thing, I assume it's WU.
Offline sho23
  • KN6DZN
    • LinkedIn
Re: Is it back up?
« Reply #2 on: January 08, 2018, 03:46:57 PM »
Welp that settles it - thanks. I guess we'll just wait until they get their ducks in a row
Offline Glenn
Re: Is it back up?
« Reply #3 on: January 09, 2018, 08:49:40 AM »
I'm getting some very odd reporting from the WU website as well. Right now, it says my station isn't reporting and the graphs are all over the place; triangles.  :lol:  (Vermont station is is showing the odd data, Connecticut station is fine currently)
Now, when I access my stations via the PWS Monitor app on my iPhone, everything is showing up fine. Oddly, that app pulls all data right from WU. So must be a website issue at this point. It seems data is there, it's just not reporting out on the website correctly.
*Edit: CT station just went offline on the website...fine on the app.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline nincehelser
Re: Is it back up?
« Reply #4 on: January 09, 2018, 08:59:25 AM »
I think the aliens are trying to communicate...
Offline NanoWx
Re: Is it back up?
« Reply #5 on: January 09, 2018, 09:06:24 AM »
If they specialize in hacking, could be trying to obfuscate, instead of communicate...
As I recall, some have noticed that local time sometimes seems to go 'wrong'. I've forgotten whether the tabular history shows both local time and gmt.
If not, one can use WxDisplayHistory.asp, which is the underlying script used by wu for history. Use parameter graphspan=day. 1st field of each record should be local time, and last field gmt. If the time offset is wrong, good chance wu has returned data for est, instead of local time zone.
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Is it back up?
« Reply #6 on: January 09, 2018, 10:01:47 AM »
Yeah random S#^T happening here too. screenshots below within a minute of each other:
Also ftp webcam works sometimes, then fails with authentication issues (I'm using the same details) then it works again.... images are below 150kb and uploaded more than 60 seconds apart.
I guess WU didnt fix their issues before, they were just sleeping...
Regards Simon
Offline railrode1
Re: Is it back up?
« Reply #7 on: January 09, 2018, 10:28:43 AM »
Davis Vantage Pro2 + Wireless
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Is it back up?
« Reply #8 on: January 09, 2018, 10:34:57 AM »
Yep but that was 6 Days ago.  does WU have an SLA with their hosts?
more likely to be issues with Intel patching due to the timing of this latest occurrence.
« Last Edit: January 09, 2018, 10:38:00 AM by Toxic »
Regards Simon
Offline jpk1018
  • http://www.madrussianweather.com/#
    • Mad Russian
Re: Is it back up?
« Reply #9 on: January 09, 2018, 11:10:21 AM »
Was going to say mine has been happy here lately but it now seems WU has crashed and burned again. Station not reporting no webcam.
« Last Edit: January 09, 2018, 11:28:27 AM by jpk1018 »
Offline DrBobDavisV2
Re: Is it back up?
« Reply #10 on: January 09, 2018, 11:24:15 AM »
same here as well as all the other local stations I query but the Mobile app seems to be working just fine.  Seems to be mostly just the PC application interface.
Offline daman
Re: Is it back up?
« Reply #11 on: January 09, 2018, 11:27:20 AM »
 :roll: It's not back up!!
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline LABob
Re: Is it back up?
« Reply #12 on: January 09, 2018, 11:43:15 AM »
Nobody gives SLAs any more, or if they do the "penalty" amounts to nothing. Like Amazon Prime's shipping, where the guaranteed 2-day delivery means that if it doesn't come in 2 days, shipping is free (which it is anyway).
Offline sho23
  • KN6DZN
    • LinkedIn
Re: Is it back up?
« Reply #13 on: January 09, 2018, 11:44:58 AM »
If you talk to their customer service, they'll typically give you some candies --- either an extra 1 month of prime, or $5 credit, or something. Keep the sheeps happy.
Offline wicked
Re: Is it back up?
« Reply #14 on: January 09, 2018, 12:37:32 PM »
I got the graph triangles this morning also. Seems to work well at times and other times not at all or bad looking data like today
Offline Glenn
Re: Is it back up?
« Reply #15 on: January 09, 2018, 01:12:23 PM »
Here's an interesting tidbit...It appears my reporting intervals have increased. I have way more data points for my wind direction than usual. Temp graphs (minus the triangles) have more reporting points as well.
Acurite 5 in 1 Pro+
Southern VT
Connecticut
Offline antstrafer
Re: Is it back up?
« Reply #16 on: January 09, 2018, 01:32:38 PM »
yep looks like reporting every minute instead of 5 minutes.  Just when you think it can't get any more fubar, a new fubar standard is set.
Davis Vantage Pro2 plus     Meteobridge
CWOP FW5142    PWS THAI817    MADIS F5142
WU KTXTHALI2    AWEKAS           weatherobs
Offline mikejeep
Re: Is it back up?
« Reply #17 on: January 09, 2018, 01:33:57 PM »
They are definitely still having severe server/network issues. The WU connection log on my meteobridge has looked like this for most of the day.. I'm configured for every 10 seconds:
2018-01-09 13:26:20 Error: No data received.  (no more tries)
2018-01-09 13:26:10 Success!
2018-01-09 13:25:56 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:25:36 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:25:26 Error: No data received.  (no more tries)
2018-01-09 13:25:10 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:24:58 Error: No data received.  (no more tries)
2018-01-09 13:24:38 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:24:24 Success!
2018-01-09 13:24:04 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:23:54 Error: No data received.  (no more tries)
2018-01-09 13:23:36 Error: No data received.  (no more tries)
2018-01-09 13:08:14 Error: No data received.  (2 more tries)
2018-01-09 13:13:18 Error: No data received.  (3 more tries)
2018-01-09 13:23:26 Error: No data received.  (5 more tries)
2018-01-09 13:23:16 Error: No data received.  (no more tries)
2018-01-09 13:03:06 Error: No data received.  (1 more tries)
2018-01-09 13:23:06 Error: No data received.  (no more tries)
2018-01-09 13:22:52 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:22:32 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:22:22 Success!
2018-01-09 13:21:58 Error: Read error (Connection timed out) in headers.  (no more tries)
2018-01-09 13:21:48 Error: No data received.  (no more tries)
2018-01-09 13:21:38 Error: No data received.  (no more tries)
Offline Catskin
Re: Is it back up?
« Reply #18 on: January 09, 2018, 05:53:34 PM »
Or you are caught in a time loop...
Offline KennyBKK
    • Khu Khot WX Station
Re: Is it back up?
« Reply #19 on: January 09, 2018, 06:16:29 PM »
I don't think they're backed up but getting worst.  Now My Weather Station page shows that I have no station registered with WU at all.
Their API page latest update mention that they have problem with their cloud servers.  May be it is raining.
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
Re: Is it back up?
« Reply #20 on: January 09, 2018, 07:27:09 PM »
looks like it has a pulse.
Offline benay ra'am
Re: Is it back up?
« Reply #21 on: January 09, 2018, 07:39:48 PM »
Put a fork in wu, I think they are done. If they do go down ( Highly Likely ) Wonder what Acurite is going to do as all their PWS they sold that do report only reports to wu. Looks like I have to get off my lazy butt, dump wu and send my data to CWOP.............................
CoCoRaHS: NC-JH-80
Offline WindyRidgeNZ
Re: Is it back up?
« Reply #22 on: January 09, 2018, 07:50:03 PM »
If only there was some sort of information service that we could use to check...
Offline nincehelser
Re: Is it back up?
« Reply #23 on: January 09, 2018, 08:05:54 PM »
Send out an update to report somewhere else.  myAcurite is already structured to support other sharing services.
Offline benay ra'am
Re: Is it back up?
« Reply #24 on: January 09, 2018, 08:09:58 PM »
Which ones?
CoCoRaHS: NC-JH-80
