Author Topic: Weather Underground  (Read 389 times)
Offline gonz33
Weather Underground
« on: July 20, 2019, 10:24:36 PM »
Greetings to all, I have a Weather Station Davis Vantage Vue for 7 years and I have decided to change it for the VP2, I share the data in Weather Underground, when I change the Weather Station I will lose my Weather Station ID: IDISTRIT89 Station Name: Montalban? Thanks.
Online PaulMy
Re: Weather Underground
« Reply #1 on: July 20, 2019, 10:43:22 PM »
No, there should not be any issue, and you can continue with the same station ID.
« Reply #2 on: July 20, 2019, 11:20:23 PM »
You may need to go into WU Station settings and change hardware tyoe from Vue to VP2 or VP2 Plus depending on which version of the VP2 you get. Especially if you get the VP2 Plus with UV and Solar Radiation. Maybe someone else with experience on this can chime in as I'm curious to know for sure. If anyone upgraded from a VP2 to a VP2 Plus did you have to specify the hardware type difference?
