That's fine - I was just suggesting where you could go to obtain suitable sealant for use with the supercap, if you want to use that.
[/quote]
thank you for the suggestion. Now I am curious on the new board, if it weren't so dang cold outside, I would take the cover off the board and see if how the supercap is seated, the bottom of the leads into the super cap. I am betting that it is the same as it always is, which makes me wonder the benefits of putting a dab of non corrosive sealer to the bottom of the super cap as a preventative or just see how things go.
On the bright side, I have an extra ISS that I can populate my last station transceiver with . I am thinking.. that I have that temperature sensor out on the soil moisture station, replacing it with the old ISS instead, then I have a solar powered unit. then buying one temperature probe and putting it in either my compost pile for the temperature (probably not) or an additional temperature sensor for maybe the temperature in the crawl space for tickles and grins.
I am retiring at the end of May from teaching and need to keep busy with some hobby. Golf is out, I don't know how to play and would be forever looking for a ball with an electronic finder circuit. or get into bootlegging in the basement.. making more mead... that might be it.
In any case, I have learned a wealth of information since I bought the WMII years ago, then the vp1 and now the Vp2.
