Author Topic: wxstatus.php  (Read 2821 times)
Offline ed2kayak
  • Ed
    • Cumberland Valley Weather
wxstatus.php
« on: February 14, 2012, 11:03:08 AM »
Confused by this:
http://cvweather.org/wxstatus.php
no update since Wed, 31-Dec-1969 7:00pm
Downloaded most recent full version WD Version on 14 February 2012 - 06:00:45 .
Ed
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
Re: wxstatus.php
« Reply #1 on: February 14, 2012, 12:15:12 PM »
Your testtags last updated at midnight
$time =  '012:10 AM';   // current time
Try fixing that first
Software: WeatherDisplay
  • Mark
Re: wxstatus.php
« Reply #2 on: February 14, 2012, 12:22:36 PM »
Your testtags seem to be updating every 5 mins, but there 12 hours off for some reason.
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #3 on: February 14, 2012, 12:30:03 PM »
Strange,
My testtags.php in my wdisplay\webfiles is empty?
Ed
  • Mark
Re: wxstatus.php
« Reply #4 on: February 14, 2012, 12:33:22 PM »
what does your testtags.txt file look like? Does it look normal?
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #5 on: February 14, 2012, 12:39:16 PM »
It looks ok to me not modified since 1/23/12.
I wounder if I'm affected by this.
http://www.weather-watch.com/smf/index.php/topic,54860.msg440401.html#msg440401
But though I had latest.
Ok, just dropped the latest zip ver in, restarting now.
We'll see what happens.
« Last Edit: February 14, 2012, 12:44:14 PM by ed2kayak »
Ed
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #6 on: February 14, 2012, 12:53:17 PM »
Ok,
Looks like latest WD zip file fixed for me.
Ed
  • Mark
Re: wxstatus.php
« Reply #7 on: February 14, 2012, 01:12:54 PM »
Cool.. Glad you got it fixed.
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #8 on: February 14, 2012, 02:48:12 PM »
Where does this come from:
Weather-Display weather data, because mine is  still stale??
Ed
  • Mark
Re: wxstatus.php
« Reply #9 on: February 14, 2012, 03:29:11 PM »
Without seeing your wxstatus script, its hard to say what file that is referring too. You should be able to tell by looking at your script. If not, attach your wxstatus script as a txt file and we can see what that is referring too.
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #10 on: February 14, 2012, 03:50:01 PM »
Here it is.
Ed
Offline C5250
    • Local weather
Re: wxstatus.php
« Reply #11 on: February 14, 2012, 04:05:30 PM »
It comes from the time/date within the wxtags file. The line above it, suggests that that file is being uploaded. Is the time on your computer correct? Or maybe there's a time zone setting in WD that isn't properly set?
Re: wxstatus.php
« Reply #12 on: February 14, 2012, 04:19:00 PM »
The issue is with your WD time setting .. you have both Use 24 hr time AND use AM/PM selected, so your testtags.php has an invalid time
$time =  '16:15 PM';   // current time
$date =  '02/14/12';   // current date
The FTP information checks the webserver's date/time v.s. the last modified time on the tags file.
The Data information checks the tag's internal date/time v.s. the current webserver's date/time
Best regards,
Ken
Offline ed2kayak
  • Ed
Re: Re: wxstatus.php
« Reply #13 on: February 14, 2012, 05:08:25 PM »
Thanks Ken,
I'll check when I get home. Didn't think I changed any WD setting recently.
Ed
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #14 on: February 14, 2012, 06:08:52 PM »
Best regards,
Ken
Where is the WD time setting?
Ed
Re: wxstatus.php
« Reply #15 on: February 14, 2012, 06:21:01 PM »
WD, Control Panel, Units&Other Settings, Precision/Time/Date/Cloud Height TAB, Date/Time area:
Choose either (but not both)
AM/PM on time (12 hour format)
  or
Use 24 hour clock
Offline ed2kayak
  • Ed
Re: wxstatus.php
« Reply #16 on: February 14, 2012, 06:49:08 PM »
I was in process of DL and updating to ver 13, before I read your reply.
This is a screen capture after my upgrade to WD ver 13.
I emphasize, I made no changes before and/or after on this screen.
Ed
Offline gwwilk
  • Southeast Lincoln Weather
Re: wxstatus.php
« Reply #17 on: February 14, 2012, 07:26:42 PM »
Confused by this:
I had the same problem this morning after updating the wd.exe to the latest version.  I forced an upload of all files via ftpupd and the status was back to normal.  When I checked it a few minutes ago the data hadn't been updated in WD (testtags.php) for 6 hrs. although the file upload was current.  Just now I downloaded Brian's latest wd.exe (v10.37R,B13) and swapped it in.  WD is now once again keeping testtags.php current according to wxstatus.php, so whatever was happening is no longer occuring.  No mention was made of this problem or of fixing it in the WD version history.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline ed2kayak
  • Ed
« Reply #18 on: February 16, 2012, 10:26:02 AM »
Tried version 14, off by 12 hours. Reverted to version 7, appears OK.
Ed
Offline gwwilk
Re: wxstatus.php
« Reply #19 on: February 16, 2012, 05:27:30 PM »
There is a thread over on the Weather-Watch.com forum in which Brian says he has updated WD this afternoon to hopefully address the problem.  We can hope that this is the end of it, but 'time will tell'.  Thus far today's new WD.exe is being nice according wxstatus.php on my site.
gwwilk@gmail.com
