Author Topic: Affiliated Regional Weather Networks  (Read 746 times)
Offline SteveFitz1
    • Tyler Texas Weather
« on: August 12, 2018, 07:13:29 PM »
Ken,
Just wondering if you have any plans to modify the script for Affiliated Regional Weather Networks to use non-Google maps like you did for the Earthquakes script.
Steve
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: Affiliated Regional Weather Networks
« Reply #1 on: August 12, 2018, 07:37:05 PM »
Ken done this a while back:
Version 4.04 - 11-Jun-2018 - updated mesonet-map-common.php, mesonet-map-genhtml-inc.php, mesonet-map-json.php to fix deprecated each() calls, correct JSON output/processing and HTML generation
Version 4.03 - 29-May-2018 - updated several .php scripts for timezone processing, updated all mesonet-map-lang-*.txt files to replace a preg_match with 'e' modifier in one function
Version 4.02 - 27-May-2018 - mesonet-map.css V4.02 adjusted z-index values in CSS to better work with Saratoga template flyout-menu set
Version 4.01 - 25-May-2018 - fixed mesonet-map-genjs-inc.php V4.01 to honor $rmProvider default map selection
Version 4.00 - 23-May-2018 - replaced Google Map with Leaflet/OpenStreetMaps functionality - no map key needed!
Regards Simon
« Reply #2 on: August 12, 2018, 08:02:41 PM »
Yes, the quake-json, mesonet-map and now global-map scripts are all Leaflet/OpenStreetMaps.
Last one to do is for nws-alerts, but I may not have it finished before vacation starting in a week...
Offline SteveFitz1
« Reply #3 on: August 12, 2018, 08:59:32 PM »
Hey Ken,
Thanks very much. Looks like another of my "impeccable timing" questions!  :grin:
Steve
