Author Topic: Lacrosse C86234  (Read 4134 times)
Offline VaJim
Lacrosse C86234
« on: October 25, 2013, 07:45:54 PM »
Saw this today at Costco..Norfolk VA
http://www.lacrossetechnology.com/c86234/
$79
Offline blizzardof78
    • Ohio Weather
Re: Lacrosse C86234
« Reply #1 on: October 25, 2013, 09:53:47 PM »
Heck of a price Jim!! Thanks for sharing. I just sent you an e-mail regarding something similar.
Don in Ohio
Offline JoesHouse
  • Joe's House at the Beach
Re: Lacrosse C86234
« Reply #2 on: October 27, 2013, 10:25:39 PM »
I'd buy one to have back up sensors!
Im checking Jacksonville tomorrow
Lacrosse WS2813 - Heavy Weather Pro  WUHU :KFLFERNA7
Offline VaJim
Re: Lacrosse C86234
« Reply #3 on: November 02, 2013, 06:07:17 AM »
$79
Turns out I had the model number wrong (at least at my local Costco).  They are selling the C84612:
http://www.lacrossetechnology.com/c84612/
This model uses their gateway instead of the usb stick.  Looks like no way to share your data across the web. :-(
Offline EarthWeather
Re: Lacrosse C84612
« Reply #4 on: January 01, 2014, 06:23:06 PM »
I am thinking about buying one of these C84612 stations. I understand from other posts that the data can be obtained in CSV format.  From there I think it would be easy to put the data in any format. Anybody out there have any further knowledge or ideas?
Also, I think the subject line of this thread should be changed to C84612... any objections?
« Last Edit: January 01, 2014, 06:27:31 PM by EarthWeather »
Offline 10ACTony
Re: Lacrosse C84612
« Reply #5 on: January 02, 2014, 12:41:21 AM »
The CVS data is available.  But only in two hour increments.  E.G. 0200,0400,0600 etc.  It looks like you can get it for 1 day, 3 days, 1 week or 1 month.
But you should also take a look at the conversation going on in Lacrosse Wireless Internet Gateway GW1000U ERF-100
No trees were destroyed in the sending of this message though a significant number of electrons were terribly inconvenienced.
Offline skydvrz
Re: Lacrosse C86234
« Reply #6 on: January 04, 2014, 01:52:59 PM »
I have developed an app that can snoop Alerts Gateway packets from a GW1000U ERF-100 (companion to a C84612 and perhaps other model weather stations) and display the current values on a Windows computer in real-time.  The Internet Gateway sends sensor data packets to the La Crosse server over the Internet every 2-4 minutes - so you would be able to record samples at that rate.  Writing to a CSV file or other data format would be easy.
I am still working out the bugs, but I do have most sensor fields working now.  The only thing that needs tweaking is current Wind Speed.  All other sensors are working.
Join us on the aforementioned thread - the discussion is rather technical at this point, but any software release announcements will be made there.  The app and source code will be free.
Offline skydvrz
Re: Lacrosse C86234
« Reply #7 on: February 28, 2014, 09:51:13 PM »
I have improved the app to allow updating your Wunderground page with C84612 sensor data every couple minutes.
This is not a web page scraper - it no longer uses the LCX cloud server at all.
You no longer need any special hardware - All you need to do is make a minor reconfiguration of your Gateway module settings and you are good to go.
It includes a mini-web server that you can use to view your tabular sensor data in your web browser.
It currently stores your sensor readings on my database server, but I will be removing that requirement in an upcoming release.  You can still store/retrieve sensor readings from Wunderground.
