Author Topic: REMOTE REBOOT - REMOTE RESET (factory)  (Read 1438 times)
Offline Cutty Sark Sailor
« on: December 04, 2016, 09:53:26 AM »
This format appears to work for me...both RED and BLUE assuming you can access the controller...
change URL and PORT as applicable
REBOOT
http://URL:12345/index.cgi?action=tools_system&auth=&reboot=Reboot...&t=
RESET (to factory default)
http://URL:12345/index.cgi?action=tools_flash&auth=&do_flash_erase=Reset+Settings&t=
 8-[ oops!  Thanks, Greg: "This needs "Need authentication:" to be unchecked,..."
« Last Edit: December 04, 2016, 03:05:24 PM by Cutty Sark Sailor »
Re: REMOTE REBOOT - REMOTE RESET (factory)
« Reply #1 on: December 08, 2016, 11:57:26 AM »
...your Banana Budget would be high...so would your battery budget
and the range would probably be limited ... so use a 12 volt wall-wart, e.g.
Get something like this... they also come with single/double buttons.
<$10-$20 US... One button for BLUE, another for RED, for e.g.  this
kit could also control the boot buttons on BLUE
Works cheaper than a monkey... and no issues with monkey missin' the hole in the out house seat,
Should work 100 M ± with 12v
This one's from here:
https://www.amazon.com/gp/product/B00UV6JNZQ/ref=od_aui_detailpages00?ie=UTF8&psc=1
14 banana$, US.
Cheers!'
Mike
« Last Edit: December 10, 2016, 10:33:33 AM by Cutty Sark Sailor »
« Reply #2 on: January 24, 2017, 09:39:44 AM »
I decided to "monkey around" with this, since the issue has resurfaced. I already have a rebooter push-button, so I can bring out the wire in parallel with that.
With some left-over gift card balance it only cost me $8.
I'll let you know how it works when it gets here and I get it installed.
« Reply #3 on: January 26, 2017, 08:45:37 AM »
It came. I'll try testing it, for now.
