Author Topic: My Weather Station!  (Read 3805 times)
Offline rhuntington3
  • Howdy!
  • Howdy!
    • My Web Site
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: My Weather Station!
« Reply #1 on: January 31, 2016, 02:50:51 PM »
Nice, it also seems like the ISS will be quite exposed to the Sun so it will be interesting how effective the radiation shield is, do you have FARS?
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #2 on: January 31, 2016, 02:52:14 PM »
Yes, I have the FARS.
« Reply #3 on: January 31, 2016, 05:16:18 PM »
Now that's a pole! Let's hope on calm, sunny days the roof won't radiate into the ISS.
Offline DoctorKnow
« Reply #4 on: January 31, 2016, 05:22:21 PM »
Wunderground has dropped your station off the map!  #-o I like the set-up!
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #5 on: January 31, 2016, 08:01:11 PM »
D'oh!  :(
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #6 on: January 31, 2016, 08:07:07 PM »
Its a 12 foot pole!  :)
Pole amounted to a Pole by Richard Huntington, on Flickr
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #7 on: January 31, 2016, 08:15:45 PM »
Seems to be back on the map now.
« Reply #8 on: January 31, 2016, 08:58:18 PM »
Well, I meant the diameter for stability sake. Watch those temps. by that roof.
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #9 on: January 31, 2016, 09:00:00 PM »
Ah.  Summer will tell.  It gets hot here and we usually end up under a high pressure dome that doesn't allow any rain at all.
« Reply #10 on: January 31, 2016, 09:09:07 PM »
You'll know long before that.
Offline Aardvark
    • turned off
« Reply #11 on: February 01, 2016, 12:57:36 AM »
I assume that you will remove those muffler clamps when you have to do maintenance on the ISS?   You know that the data you get from that setup is for your use only.     the data will be skewed for anyone who lives on the ground.
here is a good reference:
  http://www.srh.noaa.gov/images/epz/mesonet/CWOP-Siting.pdf
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #12 on: February 01, 2016, 01:06:18 AM »
Could explain better your question?  Muffler Clamps?
Offline Aardvark
    • turned off
« Reply #13 on: February 01, 2016, 01:13:38 AM »
Those clamps you used to connect the two pieces of pipe together .  Out here we call them Muffler clamps.  U-Bolts
  I suppose there is a technical term for them.   I guess you would loosen the clamps, let the unit slide down to the ground and then cleaning out the rain gauge of stuff,  the ISS Battery and any other goodies that happen in live.  Definitely I would use a drain screen in that cone and bird spikes around and in the cone
You have the thing mounted way up in the sky.  correct sitting of a weather station, you can have the wind unit up that high, but the whole ISS, would be incorrectly placed .  That is why I posted the reference for that situation.  YOur results could be either warmer or colder than standing on the ground.  Anyway,  my take on it. YOur station, Enjoy it.  It is a lot of fun.
« Last Edit: February 01, 2016, 01:18:01 AM by Aardvark »
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #14 on: February 01, 2016, 01:18:24 AM »
Ah, they are called U Bolts and yes they would have to be loosened in order to perform maintenance.  There is a drain screen in there.
Offline Aardvark
    • turned off
« Reply #15 on: February 01, 2016, 11:09:25 AM »
  Do you have the bird spikes on there as well.
  • Howdy!
  • Howdy!
    • My Web Site
« Reply #16 on: February 01, 2016, 11:33:26 AM »
No but I probably should.  I'll look into adding them soon.
