Looks good! I just tried the time lapse. About how much for a stardot? I'm using a Panasonic IP cam I got for 70 something bucks. I may upgrade down the road, but not if it's gonna be crazy expensive.
Thanks!
The StarDot is not that bad price wise for what you get compared to the other brands I've looked at.... It's not a cheap cam, but it's also not crazy expensive like some i've seen.
I've installed Panasonic, Toshiba, Axis and other brands on jobsites for clients when I was installing their wireless networking gear, so I had a pretty good idea what some of these looked like, but most were just way too much for what I wanted on a hobby website.
After looking at StarDot's example image page, it was just a no brainer for me (
http://www.stardot.com/netcamxl/samples.html ). Take a look, these images are just breathtaking.
I got the entry level XL version, the XL640. Knowing I wanted a 640X480 image, it worked out well. This model was $599.
But to get the better image quality at night and with varying light conditions, you need a camera with a automatic (not software) iris lens, so I got the 3.5-8mm AutoIris lens for another $129, but if you order it -with- the camera, they take $30 off the price of the camera since you're not using the stock lens, so really, it's only $99 for the lens.
The housing was another $129 bucks, but this camera is up 70ft off the ground on a Rohn25 guyed tower, so I didn't want to take any chances.
Now, they have a promotion going on right now i'm gonna sign up for, if you put a little icon linking to their website near the image, they'll give you a $100 rebate, so when you add it all up, it's not bad for the money.
Now on the installation, I ended up spending more than I wanted to, but it was the only way the camera would survive the environment I was putting it in. It's on almost 250ft of double shielded CAT5 cable, as it's almost 130ft from the building, 70ft up the tower itself, plus cabling in the building to the 48volt power-over-ethernet injector. I'm using Polyphaser lightning protectors in the camera's enclosure and on the ground where the CAT5 enters the building, as well as grounding the shield on the cat5 every 100ft. That combo on WiFi bridges I install for a living has worked great, and I have gear that survives strike after strike without even blinking (Motorola R56 grounding standard for the and engineers or amateur radio operators here). I then use Ethernet to Fiber converters to physically separate the Ethernet link from my network switch (again, at 70ft in the air, this tower gets hit 2-3 times a year, we are in the lightning capital of the US in West Central Florida, I am not taking any chances
So while it's ultimately probably more than I wanted to spend when all the extras were added, the end result was worth it, IMHO.
Take a look at the cam at night -and- during the day, it's image quality is just incredible.
