Author Topic: problem with heat index  (Read 576 times)
Offline NasserAbbas
« on: July 06, 2017, 11:01:01 PM »
hi guys,
how are you ?? I hope to be fine
I am from Bahrain island and the weather hot and wet
I have problem with heat index where it is disappear
before yesterday the real temperature was 43.6 and the humidity 33% but the heat index does not appear
but if the real temperature decress is appear I mean heat index
I have ambient weather ws-1001
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
Re: problem with heat index
« Reply #1 on: August 19, 2017, 12:25:19 PM »
To display the heat index - at high temperature must also be high humidity.
33% is not enough for the heat index to turn on.
