Author Topic: Meteohub with WH3080  (Read 2593 times)
Offline Nisse
« on: May 08, 2017, 03:47:54 PM »
My Oregon UV-sensor UVN800 is broken. I have had a few of them, but they will just broke after 1 to 3 years.
My question is if the WH3080 weather station is compatible with meteohub?
I see Fine Offset WH3080 and Nevada WH3080. What is the diffrence between them?
http://www.foshk.com/Weather_Professional/WH3080.html and https://www.amazon.co.uk/Nevada-WH3080-SOLAR-wireless-weather-transmitter/dp/B00CMP5PDS
Thanks.
Re: Meteohub with WH3080
« Reply #1 on: May 08, 2017, 04:17:47 PM »
Heres the list of compatible stations.  The 3080 ain't on it.
Meteohub supports these weather stations:
Oregon Scientific: WMR-918N, WMR-928(NX), WMR-968, WMR-88, WMR-100, WMR-200, WMRS-200, RMS-300
Davis: Vantage 2 pro, Vantage 1 pro (needs Firmware "B"), Vue (via RS232, USB and TCP/IP), Envoy8x and to receive data from RF sensors without need of a console/logger "Meteostick"
Peet Bros: Ultimeter 100/800/2000/2100
Hideki: TE-923 (needs HW-Revision 3 or newer), TE-821W, WXR810, DV-928 (also known as Nexus, Mebus, Irox, Honeywell, Cresta)
Fine Offset Electronics: WH-1080, WH-1081 (also known as Watson W-8681, WX-2008, National Geographic 265 NE, Elecsa 6975/ 6976, Ambient Weather WS-1080/WS-1090/WS-2080, Tycon TP1080WC)
ELV: WS300PC, WS444, WS500, WS550, WS777, WS888, WDE1
La Crosse: WS2300
RainWise: actual MkIII model (mkIIIcc and CC-3000 computer interface)
Lufft: WS-600
Adcon: A850
Toradex: OAK USB sensors for pressure and temperature
TEMPer USB stick like temperature sensor
RFXCOM: new RFXtrx model and legacy Receivers with USB (80002), LAN (81003, 83003) or WLAN (82003, 84003) for Oregon sensors
Sound Level Meter SL-814 USB
Energy Meter CC-128, ELV Em1010PC, Conrad 3000 USB, RFXCOM RFXmeter
Voltage Meter Labjack U3-HV, U3-LV (on x86 platform only)
Offline Nisse
« Reply #2 on: May 08, 2017, 04:31:36 PM »
Ok, but what does update 4.9:
  • Adds support for Lux/Solar and UV sensors of WH-3080 station to generic WH-1080 driver
mean?
Is it still possible to use WH-3080?
I´m not sure  what it means.
« Last Edit: May 09, 2017, 08:40:01 AM by Nisse »
Offline docbee
  • Moderator
    • smartbedded
« Reply #3 on: May 27, 2017, 09:26:19 AM »
WH-3080 should do with newest Meteohub version.
Offline Nisse
« Reply #4 on: May 30, 2017, 05:20:25 AM »
I have 5.0p (Build 176), should that work?
Or do I need version 5.0s?
Offline docbee
  • Moderator
    • smartbedded
« Reply #5 on: May 30, 2017, 01:25:42 PM »
any of those should do.
Offline Nisse
« Reply #6 on: May 30, 2017, 05:44:14 PM »
Ok, thanks.
I found a lot of brands for WH3080 (Fine Offset, Nevada, Profi Funk wetterstation, Excelvan). Does every brand work?
Then it´s a question about the quality of this weather station.
Offline docbee
  • Moderator
    • smartbedded
« Reply #7 on: June 04, 2017, 02:33:57 AM »
These rebranded stations are all the same, just the console housing might vary a bit,
Offline Nisse
« Reply #8 on: June 04, 2017, 03:01:39 PM »
Ok, thanks.
Offline Nisse
« Reply #9 on: June 13, 2017, 09:11:27 AM »
Is it any other weather station that is compatible with meteohub that can measure Lux/Solar and UV sensors.
I mean some cheaper weather station.
