Author Topic: worldextreams error  (Read 648 times)
Offline Ian.
    • Chatteris Weather
worldextreams error
« on: April 14, 2017, 01:05:19 AM »
Hi
I have been displaying worldextreams with no problem for a long while, yesterday I noticed an error message which I can't figure out which has stopped the script displaying any data.
Has anyone had the same issue and if so, what was the fix.
Cheers
Ian
CWOP - DW3371
PWS - ICAMBRID16
https://www.chatteris.biz
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: worldextreams error
« Reply #1 on: April 14, 2017, 07:47:51 AM »
Hi Ian,
this error means it was unable to load data from the ogimet site. I just checked the source and it works, however the ogimet page has always been very slow and I think it is getting slower and slower and question is how much slower it can get before it is unusable. At times Ive seen response times of over 20 seconds even when you go directly to ogimet.com and look from there.
I would hope this was only a temporary glitch. Is it still not working now?
Offline Jáchym
    • Meteotemplate
« Reply #2 on: April 14, 2017, 07:49:56 AM »
You could also try installing the meteotemplate world extremes plugin, which uses the same data source, so if that fails too it would suggest there is a problem in the communication between your server and ogimet.
Offline Ian.
    • Chatteris Weather
« Reply #3 on: April 14, 2017, 03:49:02 PM »
Thanks for the reply Jachym, I'll have a go at adding the plugin over the weekend to Meteotemplate, in the meantime I've taken the link off my Saratoga menu.
Cheers
Ian
CWOP - DW3371
PWS - ICAMBRID16
