Stan, if I understand you:
RED, normal operation:
On the 'center quad" of micro LEDs:
Top: GREEN, solid, GPS lock
Left: BLUE, 1 PPS clock signal flashes
Right ORANGE. Flashes on triggers
RED, Interference, fault, other. Normally off or brief flash maybe in high noise.
Those indicators should be like that regardless of display status, except when resetting, rebooting, or powering up.
The Red flashing LED on the discovery board, upper right, should flash all the time, at about 2 seconds. Why? dunno....
The Lower RED power indicator should be solid lit.
This is for system red.
Mike
btw... I think Egon suspects firmware... I am suspicious of that, unless they've changed some things on server/s... I think it's a data thing on server/s end... they may have it resolved by now, I noticed several stations,including my RED, were back up, but there seems to be some issues with detection processing on the RED data, which really doesn't make sense in a way...since Tobi hasn't changed firmware and this was across several versions.
??:I've been wrong before
