Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
I figured out how to correct pressure finally. It isn't what you would expect, do adjusted pressure, then go well into the negatives, (below 40 FT) in the elevation.
How did you do it? The functions are really screwy in the dashboard setup... Sometimes I have had to uncheck the sharing and save, then go back and check it again, save, and then it will go OK.
I figured out how to correct pressure finally. (Wunderground) It isn't what you would expect, do adjusted pressure, then go well into the negatives, (below 50 FT) in the elevation.
Quote from: DoctorKnow on January 25, 2017, 12:40:23 PMI figured out how to correct pressure finally. (Wunderground) It isn't what you would expect, do adjusted pressure, then go well into the negatives, (below 50 FT) in the elevation.I did what you said, but made the elevation higher than my actual elevation about 100 feet and it adjusted to what I want it to be. Making it negative made mine even worse from what I'm aiming for.
Quote from: DoctorKnow on January 25, 2017, 12:56:38 PMHow did you do it? The functions are really screwy in the dashboard setup... Sometimes I have had to uncheck the sharing and save, then go back and check it again, save, and then it will go OK.I did exactly that. I had to "unshare" and the share it again. I also changed what router my sharing was going through. I guess we will see!
Quote from: NachoQTPie on January 25, 2017, 09:32:19 PMQuote from: DoctorKnow on January 25, 2017, 12:56:38 PMHow did you do it? The functions are really screwy in the dashboard setup... Sometimes I have had to uncheck the sharing and save, then go back and check it again, save, and then it will go OK.I did exactly that. I had to "unshare" and the share it again. I also changed what router my sharing was going through. I guess we will see!Something isn't right. I see "no data" again.
Quote from: DoctorKnow on January 24, 2017, 09:54:06 AMQuote from: NachoQTPie on January 24, 2017, 09:15:19 AMI have no idea what's going on. It goes up, it goes down, it goes up, it goes down. My computer is on, net is stable, I've turned off the sleep mode... I am baffled why it keeps going offline! Have you checked Myacurite? Maybe you should re enter your station ID? If it keeps up, I would try the program VIS reader. I have been having problems with my setup as well. (smarthub) The pressure is way off, and rainfall keeps going to zero...I may have to try that. I am not getting texts from MyAcurite that its offline tho, just from Wunderground, so... I'm not sure.
