Author Topic: WD - Meteotemplate Stickers - stand alone  (Read 1050 times)
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« on: September 24, 2016, 08:38:04 PM »
Hi guys,
because I received several questions about this, I decided to rewrite the code for the Stickers Meteotemplate to make it work as a stand-alone script.
This means you DO NOT have to use Meteotemplate to use it, all that you need is to have the clientraw.txt periodically uploaded to your server. All instructions are included in the readme file. The zip file includes all the icons, images, scripts and works completely independently. Just unzip, upload and you are ready to use it.
The script can be downloaded in the Extras > Stand-alone scripts section at www.meteotemplate.com.
Enjoy
http://www.meteotemplate.com/web/extras.php
Only download and use this if you are not using Meteotemplate. If you use Meteotemplate and WD use the Stickers Plugin instead.
Note: If you like this script remember there are hundreds of others available if you also install the entire template, which is free and I am glad to help you should you need it or even install it from scratch ;)
Offline hankster
    • NFM Weather
Re: WD - Meteotemplate Stickers - stand alone
« Reply #1 on: September 24, 2016, 10:50:04 PM »
Tried downloading it but never got the file. I click the download icon and it take me to a page that says thanks for downloading. Using Chrome on OS-X
Offline Jáchym
    • Meteotemplate
« Reply #2 on: September 25, 2016, 02:45:36 AM »
Make sure you disable popup blocker
Offline hankster
    • NFM Weather
« Reply #3 on: September 25, 2016, 11:06:19 AM »
A lot of people use pop-up blockers. Maybe making just a download link so people don't have to jump through hoops would be an idea.
