Author Topic: Weather34 template(non meteobridge versions)  (Read 119327 times)
Offline weather34
Re: HOMEWEATHERSTATION Dashboard template
« Reply #200 on: April 22, 2017, 06:25:29 AM »
don't take this too seriously it is merely a bit of interesting fun on how it evolved , a big special thanks too Paul @ komoka he has been around since day one almost ..brian
Offline PaulMy
« Reply #201 on: April 22, 2017, 10:04:18 AM »
Thanks Brian, and it has always been a simple but impressive template and matured very well.  My oldest version that I still have in an old backup is 2015-10-09.  I've enjoyed the progress and learned along the way.  And it does show up quite well on my Galaxy S7 http://www.komokaweather.com/pws
Enjoying,
Offline okieman98
  • new and learning
« Reply #202 on: April 24, 2017, 02:18:52 AM »
what stations will work with this them
PWS ID HEALDTON
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« Reply #203 on: April 24, 2017, 06:18:07 AM »
all stations that produces realtime.txt and clientraw.txt and I guess a meteobridge based on Brian's new update release
« Last Edit: April 24, 2017, 06:19:42 AM by pimohdaimaoh »
Offline weather34
« Reply #204 on: April 24, 2017, 07:35:14 AM »
any hardware connected via  Cumulus,Weewx software,weather-display software
direct methods via meteobridge(2 methods + new simple direct method soon to be available), ws1001 ambient clones at 16 second intervals ,davis hardware via weatherlink(courtesy of Mats Sweden) ,upcoming weatherflow hardware via api or hardware.
https://weather34.com/homeweatherstation/
Offline okieman98
  • new and learning
« Reply #205 on: April 24, 2017, 10:33:13 PM »
like the look of it very nice layout since i have acurite and the cvs files i learned how to do, so might not work for my 5 and 1, wish i could have got the meteobrige but cost a little much for my budge stuck with the smart hub, thanks
PWS ID HEALDTON
Offline weather34
« Reply #206 on: April 25, 2017, 06:35:41 AM »
hello
if your csv is uploaded somewhere then it easy to implement into the template . just provide me a csv file via pm or email and i can put something together may be of benefit to others .always looking to open up hardware support options .brian
    • PIMOHWEATHER
« Reply #207 on: April 26, 2017, 08:56:42 AM »
Hello Brian, I was wondering if you check this regarding the rain graph comparison, I want to confirm from you if your conversion in rain rate is really based on your own formula? because when I check from their graphs even to WU, are all of rain rates are the same in millimeters except yours so maybe you could check it (see the attachment) and maybe you enlighten me for the conversion in your graphs. Thanks.
Offline weather34
« Reply #208 on: April 26, 2017, 09:17:26 AM »
hello
sorry cant help you much looking at the template all the conversions have been removed from the menu so no idea what the actual configuration is set to .
also all your data is stored in non metric http://pimohweather.webutu.com/pimohweather/chartswudata/2017.csv
so could be a number of different things but impossible to diagnose without access to the easyweathersetup.
sorry not much help to you ..good luck
brian
    • PIMOHWEATHER
« Reply #209 on: April 26, 2017, 09:59:00 AM »
hello
brian
Oh my bad, I didnt change the units in easyweather setup, it was set to "English" , now I set it correctly and the right rain rate shown this time. thanks for pointing me that out.
Regards,
Mike
« Last Edit: April 26, 2017, 10:04:51 AM by pimohdaimaoh »
Offline dolfs
« Reply #210 on: May 16, 2017, 03:56:00 PM »
For those of you with MeteoBridge as the source, I found some errors in an earlier upload configuration I had found somewhere. It may have been corrected after I found it, but just in case, here is my latest that seems to work. Brian, the maintainer of the template does not really want to support MeteoBridge beyond what is there right now, which is why I am publishing it.
Use:
http://www.starreveld.com/pws/mb.php?d=[DD]/[MM]/[YYYY] [hh]:[mm]:[ss] [th0temp-act] [th0hum-act] [th0dew-act] [wind0avgwind-act] [wind0wind-act] [wind0dir-act] [rain0rate-act] [rain0total-daysum] [thb0seapress-act] [wind0dir-act] [wind0wind-act=bft.0] m/s C hPa mm -- [thb0seapress-delta60:--] [rain0total-monthsum] [rain0total-yearsum] [rain0total-ydaysum] [thb0temp-act] [thb0hum-act] [wind0chill-act] [th0temp-delta60:--] [th0temp-dmax] [th0temp-dmaxtime] [th0temp-dmin] [th0temp-dmintime] [wind0avgwind-dmax] [wind0avgwind-dmaxtime] [wind0wind-dmax] [wind0wind-dmaxtime] [thb0seapress-dmax] [thb0seapress-dmaxtime] [thb0seapress-dmin] [thb0seapress-dmintime] [mbsystem-swversion:--] [mbsystem-buildnum:--] [wind0wind-max10] -- -- [uv0index-act:--] -- [sol0rad-act:--] [wind0dir-avg10:--] [rain0total-sum60] -- [mbsystem-daynightflag:--] -- [wind0dir-avg10:--] -- m -- [mbsystem-daylength:--] -- -- [uv0index-dmax:--] [th0hum-dmax] [th0hum-dmaxtime] [th0hum-dmin] [th0hum-dmintime] [th0dew-dmax] [th0dew-dmaxtime] [th0dew-dmin] [th0dew-dmintime]
--dolf
Ambient WS-1400-IP + MeteoBridge
Offline weather34
« Reply #211 on: May 16, 2017, 04:56:54 PM »
hello
as i said in the email thanks for your observations ! however let me clarify and explain you may understand why that the meteobridge-direct option within the template will be removed sooner or later.
some time ago the developer of meteobridge offered to include the option within meteobridge itself , this would make life easier and a more user friendlier way of using the option. currently having to cut and paste a mass of code is prone to error as each week i get an email of some sort and it always boils down to the cut paste of the code into meteobridge itself.
I don't own a meteobridge the solution in use was created kindly by WIM of leuvent template some time ago , in testing everything worked fine however what began to happen is users would try to use a variant of the long code and this began to throw up errors within the template and incorrect values started to appear . if the original long code supplied by WIM was used no problems arose, i still use that output to file as a test to try and replicate issues.
Now some many weeks later exactly i dont know I have only had one email/pm from the developer of meteobridge asking for a homeweatherstation logo image . Thats it thats all I have heard , i even saw a thread started on the meteohub forum which i contributed to once I was able to work my way through the endless spam messages on their forum about adidas,nike etc.. but as of today I have heard nothing more and in its current state its not really and ideal solution as it is nigh on impossible for me to help or support when problems arise.
I have said before a product like meteobridge would never get through customs without charges,translated documents,import duty and so on..so meteobridge is not something I am ever likely to own and be able offer any hands on user experience support. I think even if i was to bring one back from europe as personal luggage item it would be jumped on at re-entry due to the current security measures in place.
Also meteobridge recent changes to there licence conditions in terms of paid support this makes it all sort of not worthwhile from my perspective, whilst I appreciate a product like this needs to sustain a healthy funding to prevent it from becoming a discontinued item or a product that is no longer sustainable to produce and support .It all leaves me to think well what is the point in continuing to try and offer a template solution for something I have no experience or real understanding.
so I sincerely apologise in advance but where it is now is probably as far as it goes in terms of meteobridge use unless the meteobridge developer implements his suggestion.I see no point in offering something that doesn't work accordingly .
so please don't see it as I cant be arsed to do anything , i try to resolve most issues but meteobridge is one dark area for me.
so sorry...brian
Offline dolfs
« Reply #212 on: May 16, 2017, 05:38:19 PM »
No apology necessary. I mentioned you do not want to support it, not to diss you, but simply stating what you said, without rehashing all the reasons. You gave them anyway, and that is great. Meanwhile I know some of us do use your template with MB so I thought there was some value in publishing the string I use.
Pure copy/paste would not cause a problem, but people trying to fiddle with individual items would (and the blame would be entirely on them), in particular because everything is order dependent and items can also not be left out or added. There was some discussion a while ago about this format (only a "d" parameter in the URL), v.s. a URL with individually labelled data items. While the former was easier because it could be made to mimic existing support for Cumulus, the latter is more resilient in the face of users trying to change something as each parameter is individually named.
Either way, I suggest you add some language to your documentation that:
  • You will not do any more support for MB than what you have
  • Pick one "documented" and "tested" string and publish it, adding that it is not guaranteed, nor supported (i.e.you will not answer questions on it).
I am pretty sure that between Wim, myself, and perhaps a few others, we can agree on what that latter string should be.
--dolf
Offline badgemaker
« Reply #213 on: May 19, 2017, 03:33:57 PM »
got it all wotrking @ www.dreamhills-2.com/index.php but what do i need to do toget it to show at www.dreamhills-2.com
thanks
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #214 on: May 19, 2017, 05:23:48 PM »
Both links are equivalent and point to the same location, where exactly is your PWS site?
Offline dolfs
« Reply #215 on: May 19, 2017, 05:28:29 PM »
These links are not necessarily equivalent. It depends on the configuration of his web server. In most people's configurations they will effectively be equivalent though.
--dolf
Offline Jáchym
    • Meteotemplate
« Reply #216 on: May 19, 2017, 05:46:54 PM »
Yes, thats what I meant, I meant that if you click both of them land on the same page.
Offline badgemaker
« Reply #217 on: May 19, 2017, 06:13:41 PM »
thought i had it working but wasn't updating from cumulus I am running cumulus mx and in the data field have put http://www.dreamhills-2.com/weather the realtime.txt file is in that directory
Offline badgemaker
« Reply #218 on: May 19, 2017, 06:52:08 PM »
http://www.dreamhills-2.com/weather/index.php
if i go here then the template is showing with the right info if i just go to
 http://www.dreamhills-2.com/weather then the standard cumulus page appears but weather is not updated
Offline gus
    • Halethorpe Weather-Watch
« Reply #219 on: May 19, 2017, 07:49:10 PM »
http://www.dreamhills-2.com/weather/index.htm
delete the index.htm file to fix the problem
.htm trumping .php
Davis VP2+, LabJack w/temp sensors & 1-Wire lightning counter on AMD Athlon IIx2 220, 4GB, Windows7
Offline Jáchym
    • Meteotemplate
« Reply #220 on: May 19, 2017, 07:58:36 PM »
I think he must also stop the Cumulus updates otherwise if you just delete it, as soon as the update time comes, Cumulus will re-upload it. If you still have Cumulus uploading index.htm then you need to stop this in Cumulus.
Offline badgemaker
« Reply #221 on: May 20, 2017, 05:18:22 AM »
hi guys looks like i have most of it working but not all the far right says offline and the weather underground isn't showing i have put the weather underground station id in and also the api key(is this the password key for the station or the api key you get from the developer part of wu
Offline weather34
« Reply #222 on: May 20, 2017, 05:39:37 AM »
Hello
Your API is from the developer area it is the key example 098644671abcde12
Brian
Offline badgemaker
« Reply #223 on: May 20, 2017, 05:46:26 AM »
cheers brian seems everything ok now love the template how do i stop cumulus uploading the index.htm file so if someone goes to http://dreamhills-2.com/weather it goes to the template and not to the cumulus basic page i know its in the cumulus somewhere
« Last Edit: May 20, 2017, 05:49:42 AM by badgemaker »
Offline weather34
« Reply #224 on: May 20, 2017, 05:50:12 AM »
cheers brian just wait now to see if it sorts itself out
Hello
It will be fine just wait a few days for your chart data to build up I'm guessing that's a new wu station just setup . Hence no data for month or year but daily is working from 10am your time today. All looks good have fun..
Brian
