Author Topic: WxMesg Server and Interwarn  (Read 1244 times)
Offline SoMDWx
    • Southern Maryland Weather
« on: May 02, 2016, 07:25:21 PM »
Hi All!
For the fun of it I decided to re-install Interwarn and wanted to see if I could get WxMesg to drive the EMWIN stream. Well guess what? It does. The bulletins are updating asap, however the alert map/display does show anything. I have seen this long ago but figured it had something to do with the Interwarn servers... But I am using the EMWIN stream from WxMesg so I don't understand why the map display is not updating...
Any clues?
Jim
Offline tmabell
    • Mishawaka Weather
Re: WxMesg Server and Interwarn
« Reply #1 on: July 19, 2016, 04:29:19 PM »
Just saw this.  The reason nothing shows up on the alert map is because that map is populated by the Interwarn servers, even if you are using another source for text data.
Offline SoMDWx
« Reply #2 on: July 19, 2016, 04:52:15 PM »
Thanks.. Interwarn is soooooooooooo undependable....One day up,, 14 days down...Like the map but can't use it if it goes down all the time....
Jim
