Author Topic: Meteotemplate - new free website template  (Read 629381 times)
Re: Meteotemplate - new free website template
« Reply #7475 on: July 18, 2017, 10:00:29 AM »
Congratulations Jachym, you and Meteotemplate  have come a long way http://www.wxforum.net/index.php?topic=25900.msg249467#msg249467
Hi guys,yes... the day has finally come and I have first files to test.  Meteopage template testing - v. 0.0.0.0......
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #7476 on: July 18, 2017, 10:56:20 AM »
:D Yes Paul, that was not even 1.0, that was still 0.x Beta :)
Offline jeffm5690
    • Long Island New York Weather
Re: Meteotemplate - 2nd anniversary
« Reply #7477 on: July 18, 2017, 11:04:35 AM »
http://meteotemplate.com/blog/?p=3053 + interesting infographic :)
Enjoy :)
Amazing accomplishment Jachym!  Thank you and CHEERS!
Offline Jáchym
    • Meteotemplate
Meteotemplate - Plugin Update – Data Distribution 3.0
« Reply #7478 on: July 18, 2017, 01:52:03 PM »
Hi guys,
in this new version I added interval selector – this allows you to choose any time interval from your database, both shorter (eg. a few months) or longer (eg. the entire period of measurement). In addition, I used a new interval selector, which should be easier to use and also fully localized in terms of both language and date formats so hopefully that works too.
DEMO: http://www.meteotemplate.com/template/plugins/distributions/heatmap.php
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Block
« Reply #7479 on: July 18, 2017, 05:30:12 PM »
New Block – Weather Facts – Czech Republic
http://meteotemplate.com/blog/?p=3056
Enjoy
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #7480 on: July 19, 2017, 02:30:31 AM »
Hi Jachym, does this look right to you?
http://www.brecklandweather.com/meteotemplateextralog22017.txt
Namely the date being on a differently line but, mostly the time is HH:MK
Then confusion sets in with regards to php and 0 and the numbering of the fields, i.e. what number would UV be please?
is it 3 or 2 or is it number 1 because its the 1st sensor field discounting date and time? i was going to experiment and
find out for myself but, that time issue is stopping me going further
Parsing line 0 finished.
Checking validity of date...
Checking date and time...
There seems to be a problem with the date and time. Either it has not been parsed correctly or it is a date/time in the future! Check the format you specified and also the actual values.
There is a problem with the date and time, nothing would be imported. Check the date/time format you specified and the actual values in the file.
« Last Edit: July 19, 2017, 02:34:23 AM by Bashy »
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
« Reply #7481 on: July 19, 2017, 06:00:15 AM »
Hi Bashy,
the date on a new line seems strange and probably should not be that way (if it does not work, this is the cause).
With regards to column numbers, they are absolute, i.e. you start counting with the first field no matter if it is date, time etc.
Eg:
Fields:
Date,time,temp, humidity, UV
UV would be 4 (0,1,2,3,4), temp would be 2, time 1, date 0 and humidity 3
Offline Bashy
    • Breckland Weather
« Reply #7482 on: July 19, 2017, 06:41:11 AM »
Ah OK that makes sense, I thanks, regards to that date issue is from the files that Brian has recently added to the MT setup screen in wd.
Kind regards
Bashy
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Station Data 8.0
« Reply #7483 on: July 19, 2017, 12:32:31 PM »
http://meteotemplate.com/blog/?p=3061
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - New Block – Germany – Climate
« Reply #7484 on: July 20, 2017, 08:25:56 AM »
Hi guys,
this new block shows climate data for German cities, in the settings you can choose the default one.
- average monthly temperature
- average min/max monthly temperature
- average monthly precipitation
- average monthly number of wet days
- average monthly sunshine hours
- 40 cities available
DEMO: http://www.meteotemplate.com/template/indexBlockDemoWide.php?block=climateDE
Enjoy
Offline Andy Thompson
  • Southern Minnesota Live Weather
  • Madelia and Thompson Farms
« Reply #7485 on: July 20, 2017, 10:52:16 AM »
I tried doing the update to Version 15 this morning and I keep getting a 500 Error when I try to go to the update page. The funny thing is that it worked once, but towards the bottom of the update page it said that it could not write to the back up file to back up Version 14. Could it be something with the permissions I have set? I could use some help.
Regards,
Andy Thompson
www.somnwx.com
Offline Jáchym
    • Meteotemplate
« Reply #7486 on: July 20, 2017, 11:06:35 AM »
if it cannot create backup folder it means that the backup folder of the template is not writable for the script. All the template directories must be writable, not just the backup one, the template needs to be able to write settings files, cache files etc. and in this case also overwrite your original v14 files
Offline Johnny 5
  • Just a hobby
    • Watford Weather
« Reply #7487 on: July 20, 2017, 02:12:55 PM »
H Andy, just in case this helps, when I updated to version 15 I also had a similar problem, after looking at the folder structure I noticed the 'backup' folder was not there in the first place, so I created it with Filezilla and then the update performed perfectly.
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Database Info 3.0
« Reply #7488 on: July 21, 2017, 08:30:27 AM »
Hi guys,
I decided to redesign this block and show some extra info. First of all I changed the way the duration of measurements is displayed. Instead of showing something like 6 years = 72 months = …. days etc. it now shows something like 6 yrs, 2 months, 3 days etc.
Next I also added a “more” section, which shows all the parameters that are being logged and I also implemented the new alldataExtra table, so if you are saving data from any extra sensors, it will appear in the table as well.
DEMO: http://www.meteotemplate.com/template/indexBlockDemoNarrow.php?block=dbInfo
Enjoy
« Reply #7489 on: July 21, 2017, 09:50:17 AM »
HI all,
I got it working yesterday, but I had to shift some files around to do so. But I do have another question, on the Partner station block, what is the user name that has to go in there? I'm not sure what that means.
Regards,
Andy Thompson
www.somnwx.com
Offline jay_hoehn
    • Jay's Woodcrafts
« Reply #7490 on: July 21, 2017, 10:05:31 AM »
Andy,
I think that the user name is what you want to identify the station as.  Such as the name of the owner or the name of the site.  My user name could be Las Cruces Weather or Jay's Weather or your choice.
Jay
Davis Vantage Pro2 Plus
VVP
Weather Display
Offline Jáchym
    • Meteotemplate
« Reply #7491 on: July 21, 2017, 10:05:43 AM »
it can be anything, it is basically the name of the station shown in the block, the data is loaded based on the WU ID
Offline Jáchym
    • Meteotemplate
« Reply #7492 on: July 21, 2017, 01:26:05 PM »
Plugin Update – Station Feed 2.0
Hi guys,
- implementation of API – the current conditions data now shows the most recent values directly from the API file (previously loaded last record from database)
- now includes extra sensor data if available (UV, soil temperature, sunshine hours etc.)
- optimization
DEMO – JSON: http://www.meteotemplate.com/template/plugins/stationFeed/index.php?format=json
DEMO – XML: http://www.meteotemplate.com/template/plugins/stationFeed/index.php?format=xml
Enjoy
Offline Jáchym
    • Meteotemplate
Meteotemplate - Block Update – Station Data 8.1
« Reply #7493 on: July 22, 2017, 11:22:00 AM »
http://meteotemplate.com/blog/?p=3071
Enjoy
Offline N0BGS
« Reply #7494 on: July 23, 2017, 06:42:11 PM »
Hi All:
I switched my site over to SSL today.  All is well except the station thinks it is offline.  I've changed the path in the main setup to https://www.kpw3.com
but the current block is not displaying the current data.
Take a look:  https://www.kpw3.com/meteo
--Kurt
Offline Jáchym
    • Meteotemplate
« Reply #7495 on: July 23, 2017, 07:11:27 PM »
What software do you use for the updates? Do you use a CRON job? In such case you also need to update the CRON URL
Offline N0BGS
« Reply #7496 on: July 23, 2017, 11:22:00 PM »
I am using Cumulus. Using this, the one I had been using, with a cron job did not work:
/usr/bin/curl -s "https://localhost/meteo/update/update.php?password=xxxx
Changing it to:
/usr/bin/curl -s "https://www.kpw3.com/meteo/update/update.php?password=xxxx
Fixed it.
--K
Offline danb35
« Reply #7497 on: July 24, 2017, 09:12:36 AM »
curl is most likely dying on this because your TLS certificate isn't valid for "localhost".  There's a command-line flag you could use to tell curl to ignore the mismatch, but the better answer is to just use the proper hostname (as you've done).
Offline stewart45
    • Newlands Weather Station
« Reply #7498 on: July 25, 2017, 07:38:16 AM »
Now don't anybody jump down my throat for this one, just a polite query, or showing my ignorance, I see a lot of the text on the template with Abbr after them i.e. MaximumAbbr, does it stand for abbreviation when in this case Maximum is not an abbrevation
Offline Jáchym
    • Meteotemplate
« Reply #7499 on: July 25, 2017, 07:50:38 AM »
Solution: http://www.meteotemplate.com/web/translations/index.php
Make sure you keep those files up-to-date, people often don´t upadte the language files because in English it usually works - usually :-) Not always
