Tony:
Hm. Your pressure spiked to 1079.4 hPa again and plateaued there.
I don't know if you've ever said, so I'll ask:
Does the VP console say the pressure is 1079.4 hPa?According to the specs sheet of the VP manual, the pressure range of the VP is min: 800 hPa to max: 1080 hPa (that's probably rounded to 1080). So it seems that your barometer thinks the pressure is greater than 1080 hPa. My thoughts are that either: 1) your pressure sensor is faulty, or 2) you have a wrong setting somewhere.
I know someone else already asked, but have you double checked that your elevation setting in your VP console is correct? If that's incorrect, it will mess up the pressure readings.
If the elevation is set correctly, then I'd check to make sure you didn't calibrate (set an offset for) the barometric pressure on your VP console. It's described on page 29 of my VP-1 "Console Manual" under "Calibrating Barometric Pressure". Make sure you didn't "calibrate" the barometric pressure.
Something else that's bizarre is that
on your WU History page, your current pressure appears as 36538.3 hPa! Ironically, it appears to be 1079.4 hPa on the graph on the same page. I don't know why it wouldn't show as 1079.4 there, too. I can't explain that.
I'd say double check your elevation setting in the VP console. I believe that is the only setting that you really need for pressure. Don't define any other pressure/barometer offset in your WeatherDisplay program.
Kevin...
EDIT:
Wait a minute! On your WU History page, I changed units to English, and then in the table the pressure shows 1079.1 inches! That's too close to 1079.4 to be a coincidence. Sounds like there's a problem with pressure units.
Ah! I checked: 1079 inches of Hg equals 36539 hPa. So that's where the goofy value in the table on your WU History page came from. There seems to be a units problem (for pressure). Check your set up in your VP console again, particularly for pressure and elevation, and also look at the units.
Why don't you also close and then restart your weather software? Looks like you're using WeatherDisplay.
