Author Topic: wxindex not updating  (Read 500 times)
Offline pimohdaimaoh
  • "Be aware to our nature"
    • PIMOHWEATHER
« on: March 22, 2018, 10:26:07 AM »
Hi Sir ken need your help also,
since Jan 16, 2018 mu web doesnt updates its realtime data post, I checked all the upload links all are ok but still never updates on web. Kindly need your assistance of where the cause of problem, since I never modified this since before this problem come? Thanks in advance.
Re: wxindex not updating
« Reply #1 on: March 22, 2018, 10:53:26 AM »
In your ajaxWDwx3.js AJAX script, you are using a clientraw.txt from http://pimohweather.webutu.com/wd-pimohweather/clientraw.txt and that hasn't been updated since 16-Jan-2018.  Check your Weather-Display settings and ensure that clientraw realtime is enabled and uploading to your site.
Also, running check-fetch-times.php?show=versions on your site shows a bunch of scripts need updates to current versions -- it may be why your WU-forecast is not showing up too...  It's always good to do an occasional check like that to see if updates are needed to restore functionality when external data sources change.
« Last Edit: March 22, 2018, 11:32:21 AM by saratogaWX »
    • PIMOHWEATHER
« Reply #2 on: March 22, 2018, 12:12:40 PM »
Oh Thanks for your reminders, I thought it doesnt need to monitor its structures, now I guess I have to inspect them from time to time. Thank you Ken, will post here any concerns if theres any
