Author Topic: WeatherLink 6.x won't install on Windows 7 machine  (Read 2263 times)
Offline boss281
« on: February 20, 2018, 04:13:12 PM »
This seems to be a rare problem for the WeatherLink software, but my laptop has been kept updated and is very stable.  I'm not finding much material on troubleshooting and suggestions to change compatibility mode on the setup EXE and run as Admin haven't helped.  It always dies about 50-75% into the install with the "Thereis a problem with this Windows Installer Package.  A program..."
I can't find an updated download, although I believe it's a very late version of the SW.  It came with the USB data logger on CD...
Tech support appears out for today (Tuesday, Feb 20) so I'll have to try again on a day off next week.  Any suggestions I can try in the evenings when I get home?  I can provide HW and SW details if you think that helps diagnose the issue(s).  Note I'm pretty PC savvy (was a Windows programmer back in the day).  Thanks.
Weather Underground PWS KMDNEWWI3
Offline dupreezd
Re: WeatherLink 6.x won't install on Windows 7 machine
« Reply #1 on: February 20, 2018, 04:17:59 PM »
Any hints about the failure in the Windows Log Files?
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Online johnd
« Reply #2 on: February 20, 2018, 04:37:55 PM »
Hmm, wouldn't be surprised if the CD isn't perfect, or at least the combination of the CD and drive may not be perfect. Any possibility of being able to copy the CD contents on to C:\ and trying the install from there?
Cambridge UK
Offline Mattk
« Reply #3 on: February 20, 2018, 05:31:31 PM »
Which 6.x are you specifically trying to install? There are 3 full versions and 3 upgrade versions.
Offline boss281
« Reply #4 on: February 20, 2018, 05:59:49 PM »
Here is the error: "Product: WeatherLink 6.0.3 -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.  Action _1B757A12_ACB8_439C_9886_8C790D84641B, location: C:\WeatherLink\Support\Drivers\USB To UART Drivers 5.30\CP210xVCPInstaller.exe, command: /Install "
Offline dupreezd
« Reply #5 on: February 20, 2018, 06:20:21 PM »
Seems like Windows error 1722 is quite common.
Just Google it and there plenty instructions how to fix it. Hopefully it will solve yours.
CWOP - FW0717
Blitzortung 2100
Online johnd
« Reply #6 on: February 21, 2018, 02:59:44 AM »
Ah, so it's the USB driver that's causing the error. You don't have the USB logger connected during the attempted install do you?
Cambridge UK
Offline boss281
« Reply #7 on: February 21, 2018, 11:31:49 AM »
No, nothing else inserted in USB ports...
Sent from my XT1254 using Tapatalk
Offline shirsch
« Reply #8 on: February 21, 2018, 06:09:34 PM »
I had the same problem and contacted Davis. They gave me a Version 5 and it worked fine.
Offline boss281
« Reply #9 on: February 21, 2018, 07:14:46 PM »
Once you installed version 5, were you able to upgrade to the later version?
Offline shirsch
« Reply #10 on: February 21, 2018, 07:29:32 PM »
no it is something to do with .net framework. I havent been able to figure it out so I go with v5
Offline boss281
« Reply #11 on: February 22, 2018, 11:32:06 AM »
Success!  After calling tech support and talking with Drew (outstanding support!), I was sent a version of the software install without the drivers which went fine, then directed to a website to download and install the drivers separately, also successfully.  I'm up and running!  Onward to connecting to WeatherLink network, CWOP and WeatherUnderground, then decide if this works fine or just send the AmbientWeather metobridge back.
UPDATE: and I'm up on WeatherLink (JWJordans).  Now to figure out how to connect to Weather Underground.
« Last Edit: February 22, 2018, 12:17:25 PM by boss281 »
