Rather than start a new post, I'll continue this novel...
I had 1 of 2 choices in where to place my station. I chose one that I figured would have less obstructions. What is the best way to detect any anomalies or inaccuracies of my station? The nearest airport is about 7 miles away and in open space unlike my residential location. Comparing my wind readings to the airport's, they are getting steady 10-15mph winds and I'm averaging about 1-2 mph over a 10 min span (as noted on the console). I have had gusts up to 14 mph but just curious if I've located it in a bad spot. I posted pic's below.
Location 1 and the current location. I figured the space between the houses would open up more opportunity to capture better readings. Thought air would flow better between the two houses. East is blocked by the house apparently. Station is about 15-17' from the neighbors house and about 8-10' from my house.
Highest part of railing. Would sit 10-15' above ground and approx. 17-20' away from house.
I may have to wait for a better wind event but are there any opinions on which location you would think is better?
