Author Topic: *************help please read emergency**********************  (Read 5589 times)
Offline Blairsville Weather- Caleb
    • Blairsville Weather
« on: August 17, 2008, 12:24:05 AM »
as you know tropical storm fay is approaching i live on the east coast of florida
my wind direction shows but not speed    is it a conector or could it be something inside the vein the cups are still spining im going out to check it tomorrow    before i goto the trouble can anyone help????
davis   weather wizard III
Re: *************help please read emergency**********************
« Reply #1 on: August 17, 2008, 12:55:41 AM »
I have a VP1, but the anemometer assembly is pretty much the same.
From the Davis manual for the Anemometer (Weather Wizard III) it says
Wind speed reads 0 all the time or intermittently
• Make sure anemometer cable is plugged into the jack marked WIND on the
junction box.
• Check for broken wire along length of anemometer cable. Carefully check
areas where the cable has been secured.
• Try dropping the wind cups approximately 1/16” to 1/8” (1.5 to 3 mm) lower
on the mounting shaft. Use the included Allen wrench to loosen and retighten
the wind cup assembly.
• If you still do not get a reading, the problem is probably with the anemometer.
Contact Davis Technical Support for return authorization.
as the only troubleshooting suggested for zero wind-speed.  I'd suggest you contact Davis at their 800 number.
I hope you've made ready for the approaching storm and all fares well with you!
Best regards,
Ken
« Reply #2 on: August 17, 2008, 11:42:16 AM »
thanks
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #3 on: August 17, 2008, 06:40:52 PM »
If it comes down to a bad reed switch in the anemometer, tapping on the mast with a hammer while the wind is blowing might bring it back to operation temporarily for a few minutes or days.   ;)
« Reply #4 on: August 17, 2008, 08:23:06 PM »
got it workin one of my connections wa corroded cause of rain
Offline WeatherBeacon
  • Chief
    • http://www.wxbeacon.com
« Reply #5 on: August 17, 2008, 10:13:12 PM »
Pineisland, what did you do to fix it?
Thanks.
Kevin...
Mae govannen!
« Reply #6 on: August 18, 2008, 08:26:38 PM »
well i have a connector wrapped with electrical tape  water got inside and corroded the contacts
Offline SLOweather
    • Weatherelement Moline IL
« Reply #7 on: August 18, 2008, 09:31:08 PM »
As you have learned, electrical tape by itself is not a reliable way to waterproof a connection. Depending on your needs, you could use "liquid electrical tape", Plasti-Dip, linerless rubber electrical tape, or a really thick sticky rubbery tape like Vapo-Wrap or 3M Scotch 06147 Vinyl Mastic Moisture Seal Tape.
In any case, put a layer of good quality electrical tape like Scotch 33+ over anything else. Outdoor weatherproofing is not the place to use cheapo drugstore electrical tape.
A really watertight (but non-removable) splice enclosure can be made from an enclosure like a pill bottle or 35mm film can. Run the cable through the bottom, put the splice inside, and then pot it with 5 minute epoxy or maybe RTV silicone.
Another way to waterproof individual wire splices is to use silicone gel-filled phone splices, like THESE from Rat Shack. These are what Davis sends when you need to replace your anemometer/wind vane. Note: Unless you really only need 4, these are vastly overpriced at the Shack. You can generally get them in boxes of 100 for 12-15 bucks at an electrical supply house or on-line. Look for "UR" connectors.
Offline GregJ
    • http://www.SkunkBayWeather.com
« Reply #8 on: August 18, 2008, 11:46:57 PM »
The way I make all the waterproof connections on my boat is to use heat shrink tubing filled with silicone before I heat it.  This makes a very waterproof seal and it's relatively cheap.
Greg
Davis VP2 with VWS
"Everybody talks about the weather, but nobody does anything about it." -- Mark Twain
Offline Clammer
    • Weather "On the Beach"
« Reply #9 on: August 22, 2008, 08:15:50 PM »
Amen to your solution Greg!!!
Clammer
« Reply #10 on: August 23, 2008, 08:42:50 AM »
thats what i did with my last station
