Adding to what Anole mentioned in the previous post, StartWatch has the ability to simulate common UI interaction (button pushes, menu selections, etc) after a program has started. Right now, it only does this for WeatherLink. However, if people suggest a common action or series of actions for a commonly used program, I can add the same sort of special option as I've added for WeatherLink. If it seems of general usefulness, theres a good chance I will add it to StartWatch for everyone's benefit, and growing the usefulness of StartWatch.
If there's a program that you run that's not of general interest or an action sequence that would likely only be of interest to you, I can add custom options that would only show up in your copy of StartWatch (which would use the registration serial number to know whether to expose them or not). I'd have to charge for this kind of private customization, but for simple things (like I've done for WeatherLink) the charge would be under $50. I've set it up so I can add these things fairly easily. It does require that I be able to run the program (you will need to provide me a copy), so I can determine precisely what I need to send to the program to get it perform the desired actions. For more complicated action sequences such as those involving multiple actions and popping up and automatically interacting with other windows within that program, the charge would be a little more.
Steve
