Author Topic: What's Your Rainwise Web Site?  (Read 6765 times)
Offline blizzardof78
    • Ohio Weather
« on: May 05, 2014, 06:43:10 PM »
Myself and Jim from Virginia have been in search of a location where we can see Rainwise stations plotted on a map. We haven't had much luck. I have located three others besides my own (this includes Jim's). If you have the IP-100 you know what I'm in search of. My web site through RW is https://rainwise.net/weather/don43832 What's yours?
Don in Ohio
Offline Feelgood Ranch
    • Feelgood Ranch Weather
Re: What's Your Rainwise Web Site?
« Reply #1 on: May 06, 2014, 04:14:09 PM »
Ken Keyes
RainWise MkIII-LR, WeatherView 32 v8, StarDotXL 3mp cam, Boltek PCI lightning detector/L2K, CWOP/CW4669, Weather For You
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMTBOZEM2&wuSelect=PWS
http://www.anythingweather.com/current.aspx?id=22721
Offline weatherjim
    • Town of Providence, NY
Jim
Upstate NY near the Great Sacandaga Lake and
Foothills of the Adirondack Mts.
Rainwise MK III LR
IP-100 data logger
CC-3000 data logger
WeatherSnoop Software
WeatherUnderground KNYGALWA12
CWOP EW5524
Offline ValentineWeather
« Reply #3 on: May 06, 2014, 10:50:56 PM »
Ken looks like you were really wet today. High humidity 233% :?:
Randy
« Reply #4 on: May 06, 2014, 11:01:33 PM »
Must be a glitch in IP-100. Will not get excited unless does not correct next 48 hrs. Has been raining all day and snow expected tonight.
Ken
Ken Keyes
« Reply #5 on: May 06, 2014, 11:32:18 PM »
I've had those glitches before also.
Randy
Offline VaJim
« Reply #6 on: May 07, 2014, 07:03:53 PM »
Offline WA7FWF
  • Blitzortung 1196
« Reply #7 on: August 06, 2014, 11:16:21 AM »
https://www.rainwise.net/weather/WA6FWF   central valley california
Kevin
Offline ggsteve
« Reply #8 on: October 25, 2014, 04:25:41 PM »
New to the party!  https://rainwise.net/weather/steve01474 in central MA on the NH boarder.
Offline FR_Ranch
« Reply #9 on: November 05, 2014, 06:01:24 PM »
I've been having trouble with WU not receiving my data recently (it's completely stopped now) and I wanted to check on Rainwise to see if it was coming through there. My url is http://rainwise.net/weather/FR_Ranch_78737 . However, that no longer works. I get an error message that says Sorry, we can't find that weather page!
https://rainwise.net//weather/FR_Ranch_78737 .
My email to support@rainwise.com just bounced back.
Is there a new support address? Can anyone else get to my weather page?
    • Ohio Weather
« Reply #10 on: November 05, 2014, 06:04:25 PM »
I can't access it either.
Offline VaJim
« Reply #11 on: November 05, 2014, 06:13:21 PM »
try this:
https://rainwise.net///weather/FRRanch78737
but it says...'no signal'
Is your IP-100 plugged in to the AC outlet as well as your router?
« Last Edit: November 05, 2014, 06:15:15 PM by VaJim »
Offline ggsteve
« Reply #12 on: November 05, 2014, 06:26:23 PM »
I'm getting errors accessing your page too, and no data on the link the VAJim posted.
Offline VaJim
« Reply #13 on: November 05, 2014, 06:32:27 PM »
My guess his IP-100 is offline.  However now I'm seeing other stations reporting 'offline'  Might be a glitch with the Rainwise server.
« Last Edit: November 05, 2014, 06:34:04 PM by VaJim »
Offline VaJim
« Reply #14 on: November 05, 2014, 06:36:19 PM »
Check yours.
Offline ggsteve
« Reply #15 on: November 05, 2014, 06:42:44 PM »
I can get to mine and all the ones I tested in this thread except for FR_Ranch.
Offline VaJim
« Reply #16 on: November 05, 2014, 06:46:01 PM »
yeah...but....when I just checked your it says no radio signal.
Offline FR_Ranch
« Reply #17 on: November 05, 2014, 06:46:45 PM »
Thanks for the new url. I guess someone didn't like the underscore characters.
I can access the IP-100 through my browser and get this message "No data is being received from the weather station!" so it's not receiving from my station.
It's been up for a few years without too much trouble until lately. My Oracle display has been going to dashes pretty often recently but it's operating fine right now.
Today has been dark and wet all day so it could be the battery in the station I guess. It last went down about 11 today and not a peep since then. http://www.wunderground.com/personal-weather-station/dashboard?ID=KTXAUSTI216 .
I did reset the IP-100 a couple of hours ago and again just now by removing power for a few minutes.
Any ideas other than the station battery?
I'll be flummoxed. It just started transmitting again!
Offline VaJim
« Reply #18 on: November 05, 2014, 06:49:04 PM »
....dashes on the display is usually caused my no signal....which may mean low battery.
Offline FR_Ranch
« Reply #19 on: November 05, 2014, 06:59:53 PM »
Thanks for all of your suggestions.
Now that I can see active IP-100 data through the browser I see 6.3 volts so that's probably not the problem right?
I will continue to monitor. If it's more appropriate to post this in a different thread just let me know.
Gary
Offline weatherjim
« Reply #20 on: November 05, 2014, 07:04:22 PM »
Most likely the station battery, it should be around 5.5 to 6.0 volts when its dark out. Mine is reading 6.9 volts at the moment. shorter days, colder temperature  and battery age could be impacting the station operation. I had a bad battery a year age and had the same issue.
Jim
Rainwise MK III LR
IP-100 data logger
CC-3000 data logger
CWOP EW5524
Offline VaJim
Offline VaJim
« Reply #22 on: November 05, 2014, 07:08:32 PM »
Gary
Gary:  I'm still seeing 'No Radio Signal' on your page.
Offline VaJim
« Reply #23 on: November 05, 2014, 07:18:04 PM »
Gary
all is well now
Offline FR_Ranch
« Reply #24 on: November 05, 2014, 07:39:41 PM »
It does seem to be going in and out. I moved the device around in my wiring closet to separate it from my router and cable modem. It looked like that helped but there are still intermittent spaces every few minutes. It won't hurt to replace the battery since it's a few years old. I'll do that and go from there after the rain stops in a day or two.
Thanks for the battery url.
