OK, I finally got a driver that "shows" as working properly. But WL cant detect my station. I have a VV station, but WL doesn't have that station model available in the setup walkthrough. I also have both the driver and station set at the highest baud rate of 19200. Can I update to a newer WL version? Im using 5.7.1
My VV is currently running on ver 2.14 I read somewhere, that I shouldn't upgrade past 3.0 with the type of station I have. I believe, because of my model number, that my station is a pre-green dot station and the logger I purchased should work with it.
I went ahead and upgraded to WL 6.0.3, but still no detection. I have my baud rates identical, my driver for the adaptor is showing working in port 3, I have "serial" check marked when doing the walkthrough but it still doesn't detect the station. Ive aslo tried in Cumulus, but it cant detect the station either. The logger Im using is 6510C. Ive tried changing ports and nothing. Im at my wits end. Why does something so seemingly easy have to be so difficult?
