Author Topic: observerIP access extremely slow - is that normal?  (Read 1724 times)
Offline timg11
« on: January 27, 2018, 02:47:08 PM »
Hi. I'm have a new Ambient weather observerIP 4.1 (version 4.1.3) connected to Weather Station Model Number WS-1400-IP.
The observerIP is connected by Ethernet to my LAN.
I'm planning to set up local logging, but I want to be sure everything is working normally before making any changes.
The strange behavior I see is when connecting to observerIP at its local IP address on my LAN using a browser from another computer.
The page loading is almost comically slow. Loading the "live data" page takes about 5 minutes, with 15-20 second pauses for each row or item on a row.
Does this extreme slowness indicate a hardware problem with the ObserverIP or the WS-1400-IP?
It does seem to be sending valid data to weather underground.
Offline dupreezd
Re: observerIP access extremely slow - is that normal?
« Reply #1 on: January 27, 2018, 02:55:10 PM »
I notice that from time to time as well. A quick reboot and all is well again. When the slow down happens, I notice gaps in my data to WU.
Might be a memory leek.
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
Offline plb4333
« Reply #2 on: March 21, 2018, 05:00:37 PM »
You might also want to upgrade to version 4.36 and then reboot. At last resort, there's a pin hole on the back for resetting the ObserverIP
Offline quailvalleywx
« Reply #3 on: March 24, 2018, 06:02:40 PM »
I had seen the same slow down with version 3.1.2.  For now I send a software reboot command a couple nights a week and that seems to stay ahead of the memory leak and keep things fast.  I use this shell command from the Tasker app on an Android phone but it should work with a Linux machine, maybe even Windows powershell? if you can pipe the input:
(sleep 4;echo admin;sleep 4;echo admin;sleep 2;echo reboot;sleep 2)|telnet 192.168.1.175
Ambient Weather took telnet out of ObserverIP in later versions so you may have to flash an earlier version for telnet use.  Of course the real question is why haven't they fixed the slowness :(
Have you seen this page for potentially logging data?
https://obrienlabs.net/redirecting-weather-station-data-from-observerip/
Pat grabs the WU HTTP message locally and then forwards it to WU.
I save the data via a mysql database after implementing Pat's redirect via this php file: https://github.com/mrcodegh/SoilSensor_ESP12f/blob/master/updateweatherstation.php
WS-1400-IP, Galaxy S3 for cloud cam and Web Server
QV Website | Source Code | WU | WC | PWS | MesoWest/CWOP
Offline dupreezd
« Reply #4 on: March 24, 2018, 06:51:37 PM »
After upgrading to 4.2.1, I might experience the slowdown every 3 to 4 months.
Ambient just released a new update to address this issue, BUT no telnet option anymore.
I am doing the same thing via the re-direct, but just store the data in a flat file, not SQL.
Regards
CWOP - FW0717
Blitzortung 2100
Offline KennyBKK
    • Khu Khot WX Station
« Reply #5 on: June 17, 2018, 09:27:22 AM »
4.4.2 which they claim to fix the slow response of the Observer IP over time also has reboot loop which start on my unit last week.  Now they have 4.4.4 beta claim to fix this.  Installed and wait to see.
Kanok
Ambient Weather WS-1900
WUnderground, PWS - IPATHUMT2
CWOP - EW4214
http://kanok.net/pws
