Author Topic: Davis still using the CC1021 in current VP2 and/or VUE hardware?  (Read 6204 times)
Offline Old Tele man
  • Singing in the rain...
Re: Davis still using the CC1021 in current VP2 and/or VUE hardware?
« Reply #50 on: January 18, 2018, 02:38:01 PM »
So, does, anybody know what "clock" chip the two consoles use? Same device or different? Is the same device used for internal timing, or are separate clocking sources used?
I raise this question because my experience has been that my VP2 console clock timing was terrible (always losing time) while the replacement VUE console clock seems to be quite accurate.
« Last Edit: January 18, 2018, 02:44:12 PM by Old Tele man »
Offline rdsman
« Reply #51 on: January 18, 2018, 03:07:27 PM »
There isn't a real time "clock" chip in either console.  The processor keeps time with a clock crystal.
Ray
« Reply #52 on: January 18, 2018, 03:20:27 PM »
A raw crystal? Usually there's a divide-by-N "chip" used to derive the desired 'clock' timing.
Offline rdsman
« Reply #53 on: January 18, 2018, 03:59:07 PM »
See:
http://ww1.microchip.com/downloads/en/AppNotes/Atmel-1259-Real-Time-Clock-RTC-Using-the-Asynchronous-Timer_AP-Note_AVR134.pdf
Ray
« Reply #54 on: January 18, 2018, 06:05:47 PM »
See:
Yep, that's what the industry calls a Real Time Clock (RTC) chip. The external "oscillator" is a crystal that is oscillating at many, many, many times faster than the end/desired "clock" output...typically about 10X faster but can vary. The greater the difference between the oscillator input and the clock output, the tighter the operating tolerance (less variance).
Offline LABob
« Reply #55 on: January 20, 2018, 08:51:42 AM »
Sorry to be a little OT, but is this why some clocks drift a couple of minutes a week vs. some that can drift less than a second per week? I've always figured that products with a super inaccurate clock were a sign of corner cutting on other electronic components as well.
