Hi
The original 4001 had the capability to implement an RS232 port but it was not reliable since the processor might be in the middle of sending data on the RS232 port and get interrupted for something else and never come back to the port for a while. The manual shows the wiring to add the RS232 port.
D8apros processor upgrade fixes that problem, now you can wire a DB9 to his board instead of a DB25.
I have a cheap wireless weather station, WS1080, for reporting to the internet and leave my 4001 for instant readings in the living room.
Bearings for the 4001/5001 booms can be found on VBX.com
As stated on another post the IR diodes and transistors are prone to lightning EMP pulses. If your getting strange readings suspect the IR components.
There are easy ways to test if it's a console problem or a boom problem.
Hope this helps.
Steve
How is your Heathkit treating you? I've had my 4001 since 1987 and it has been wonderfully reliable. The only issues I've had are with the wind sensors LEDs getting funky and sending strange readings to the display. They need to be replaced every so often. There's a vendor that sells LEDs and other components for the sensors.
I installed D8aPro's CPU upgrade a few years ago so I can send data to WxUnderground and other online data sites.
Hello Lord Volvo... Kettering, Ohio!!?? I'm on the other side of Ohio just north of I-70 near Cambridge!! Heck, it'd be cool to pay you a visit sometime!!!
The only thing I have noticed, and maybe you have too, is that after that storm moved through just after Christmas with the freezing rain and sleet, the anemometer like freezes up not far under 32 degrees, but it 'thaws' during the day and spins again. I'm suspect that the bearings need replaced in it to begin with, but the previously mention activity seems a bit odd. Your thoughts?
As far as I can tell it doesn't have the serial port to send info to the web, I wish it did!! Anyhow, get back to me on that possible visit! Would love to check out your station(s) sometime! Thanks!!
Don in Cambridge, Ohio
