Author Topic: What would happen if the world were tilted at 10 degrees? How about 40 degrees?  (Read 1214 times)
Offline jellyhead
What would happen in both situations?
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
You have the answer in this thread jellyhead....
http://www.wxforum.net/index.php?topic=29948.msg294572#msg294572
Offline ericfynne
Whoever did it would be in serious trouble.
Offline jellyhead
You may say I'm a dreamer, but I'm not the only one:
http://www.worlddreambank.org/P/PLANETS.HTM
Offline Jáchym
    • Meteotemplate
No, but the problem is that you are asking questions where you give very precise details, like Europe shifted 10° North, Asia 40°S etc etc and obviously no-one can give you an answer for it. I told you to read about the Butterfly effect for example. Then you might understand why your questions are irrelevant, because whoever tries to give some answer is only guessing, and it could be just as well the other way around. So there is no point in discussing this.
