Author Topic: AWOS: KBHB - Bar Harbor - Hancock County Airport  (Read 1974 times)
Offline kbellis
« on: January 12, 2019, 01:23:01 PM »
Offline kbellis
Re: AWOS: KBHB - Bar Harbor - Hancock County Airport
« Reply #1 on: January 12, 2019, 02:42:24 PM »
Offline Old Tele man
  • Singing in the rain...
« Reply #2 on: January 12, 2019, 09:24:51 PM »
What?  You expect the Gooberment to get things right/correct/perfect the first time?
It's obvious they used the known AIRPORT lat & long, not the 'unknown' AWOS lat & long.
« Last Edit: January 12, 2019, 09:26:28 PM by Old Tele man »
« Reply #3 on: January 13, 2019, 08:05:19 AM »
Have a similar issue down here. AWOS station KVVG is located at the bottom of the pic. At the top of the image is where they say it's at. Contacted them, they acknowledged, and nothing was done.
Offline kbellis
« Reply #4 on: January 13, 2019, 08:08:05 AM »
Do you mean that you contacted the FAA?
Offline kbellis
« Reply #5 on: January 13, 2019, 08:08:51 AM »
Or Philip Gladstone?
« Reply #6 on: January 13, 2019, 10:06:04 AM »
Contacted the NWS in Jacksonville.
Offline Vette-kid
« Reply #7 on: June 30, 2019, 08:49:58 AM »
Guess I fail to see the major issue here.  Just that the location is off by a small amount?  What am I missing?
« Reply #8 on: June 30, 2019, 02:32:30 PM »
Gooberment adherence to "Close Enuf" mentality, which typically only gets applied to Horseshoes, Hand grenades and H-bombs.
Offline SoMDWx
    • Southern Maryland Weather
« Reply #9 on: June 30, 2019, 02:54:19 PM »
yawn............................................................... :roll:
Offline Vette-kid
« Reply #10 on: June 30, 2019, 03:47:09 PM »
Speaking as a pilot... It's close enough.
It appears that the listed location is actually the center of the aerodromes, for Wich the identified is KBHB.  in both cases it's possible that the actual location is in the same spot as an old NAVAID, (NDB OR VOR).  Not worth the effort to move the weather station when the NAVAID moved or was taken out of service.  Not saying that's for sure the case, but some possibilities
Offline WeatherHost
« Reply #11 on: July 01, 2019, 12:50:21 AM »
I see a bunch of pictures, but no words from the OP.  Is there a question here?  Compliant?  Issue?
Based on the replies, I'm gathering OP is asking about location accuracy?  Or maybe something else?
Weather may change over a mile or two, but rarely overly a few hundred yards.  So, unless planes are crashing into it, I don't get the point?
« Reply #12 on: July 01, 2019, 12:20:34 PM »
When something is measured to 3 or 4 decimal places (ie: Lat & Long), it's ASSUMED the results reflect the accuracy of those extra decimal places.
