Weather Station Hardware => Blitzortung => Topic started by: Cutty Sark Sailor on September 29, 2017, 06:45:01 PM
OPERATORS
I You are running an A/D sample rate other than 500kHZ your signals will no longer be accepted.
Under A/D CONVERTER make sure your 'Sample Rate' is 500kHz, and save.
See this post on Blitzortung 'internal' board ... it also includes a
list of known stations with rates that must be changed.... check yours anyway.
http://forum.blitzortung.org/showthread.php?tid=2344
Mike
Thanks for posting this. It must have been the default, since both my RED and BLUE were both set to 500K. I never saw a reason to change this.
Thanks Mike,
Looks like my 969 is not one of the stations listed and it was already at 500 kHz.
It has been so long ago I last logged in to the forum I had to find my notes so I could get in :oops:
Yes 500 kHz is default....
