Author Topic: Anyone seen this  (Read 1409 times)
Offline DaculaWeather
    • North Georgia Weather
Anyone seen this
« on: November 10, 2017, 04:09:06 AM »
Using Ken's forecast script. I've never seen it until this morning. I checked on the the NWS site and the text is correct there.
Offline UpstateWeather.com
  • Signature
    • Upstate Weather
Re: Anyone seen this
« Reply #1 on: November 10, 2017, 06:31:27 AM »
I’m having the same issue. It’s not just you.
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #2 on: November 10, 2017, 07:53:53 AM »
I checked my script and it works fine
http://www.meteotemplate.com/template/indexBlockDemoWide.php?block=nwsForecast
Which data source does Ken use? Looks like they changed format of it
« Reply #3 on: November 10, 2017, 08:38:00 AM »
if ($useProdNWS) {
  // final production URLs
  define('APIURL', "https://api.weather.gov");
  define('FCSTURL', "https://forecast.weather.gov");
  define('ALERTAPIURL', 'https://api.weather.gov/alerts?active=1&zone=');
  define('ALERTURL', 'https://alerts.weather.gov/products/');
Offline Jáchym
    • Meteotemplate
« Reply #4 on: November 10, 2017, 08:58:27 AM »
OK I would need to see the rest of the script, I personally dont use this page, what we need to find is the line that parses the wind
« Reply #5 on: November 10, 2017, 09:01:22 AM »
« Reply #6 on: November 10, 2017, 09:22:08 AM »
It's just the text descriptions that are messed up. The icons, temps, and short description are ok.
« Reply #7 on: November 10, 2017, 09:24:20 AM »
Here's the raw page without formatting:
http://www.daculaweather.com/advforecast_dropdown2.php
Offline Jáchym
    • Meteotemplate
« Reply #8 on: November 10, 2017, 09:31:03 AM »
Yes, but this is useless to me because I only see the output, which obviously is incorrect, but I would need to see the actual code and how this output was generated
« Reply #9 on: November 10, 2017, 09:41:28 AM »
Interestingly enough, when I use a different forecast office, it works correctly
http://www.daculaweather.com/4_park_gsmnp.php
« Reply #10 on: November 10, 2017, 10:28:52 AM »
And it's only the point forecast, the zone is correct.
« Reply #11 on: November 10, 2017, 11:43:16 AM »
Found the issue. I spoke with our NWS office here (I have NWSChat access) and this was the answer:
"Hi Steve - thanks, yes we have been working on and appears to have been a publishing issue of a weather grid - should be fixing soon"
It is apparently only FFC's problem right now (that I can tell)
Offline n7xrd
    • Kamiah Weather
« Reply #12 on: November 11, 2017, 03:58:35 PM »
 :grin:  I just noticed mine is messed up too!!  -146mh wind expected today!!
« Reply #13 on: November 11, 2017, 06:31:56 PM »
I would contact your NWS office and let them know, and also let them know FFC (Atlanta) had the same issue the other day. It only affects the point forecast and not the zone, or at least that's the way it was here.
