Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
Ya the batteries will be a pain but I wanted it to be as accurate as possible. Trying to find a good area for these all in ones is a compromise. Leveling it I used a magnetic level that stuck to the pipe and then I would adjust the arm braces coming off the rafters until level. I wasn't about to try and eye ball that level on the 5 in 1. I know it probably not dead on but is close.
Looks good benny! I'll be interested to see if the heat radiating off your roof has any influence on your daytime temperature. Here's mine, and that's my main concern. I do need to switch over to GSP though b/c the PVC has a little too much play in it. I do plan on moving it away from the roof about another foot or so, and maybe another foot higher once switched to GSP.
I checked the station on WU, it appears to be working very well!
Have a question, is that "L" pipe apparatus using PVC? If so, I'd be concerned about the stability especially in strong winds. Last thing you'll want is to find it smashed on the ground on a windy day. Just saying.
Quote from: Skywatch on December 10, 2015, 05:39:31 PMHave a question, is that "L" pipe apparatus using PVC? If so, I'd be concerned about the stability especially in strong winds. Last thing you'll want is to find it smashed on the ground on a windy day. Just saying.On mine, yes that is PVC. I will be changing it out to GSP in the coming days though...hopefully prior to Sunday when a squall line is forecast to move through
