Author Topic: Erroneus pressure readings  (Read 581 times)
Offline MvdI
« on: June 08, 2019, 03:22:28 AM »
Hi everyone
I recently received an Alecto WS-5500 as an early birthday present, have set everything up, registered it on wunderground and weathercloud, cool!
However, the atmospheric pressure was way too high, so I calibrated the station using the indoor unit. It shows correctly on the indoor unit (1026.6 hPa), but it's reporting 1058.1 in the WS-tool app (absolute I assume), 1047.5 on weathercloud and 1058.25 on wunderground (station ID IFLLIN2)! Altitude is 371m, current temperature 13.5°C.
Does anyone have an idea how I can fix this? Is my brand new WS defective?
Many thanks in advance and greetings from sunny  8-) Switzerland
Offline nincehelser
Re: Erroneus pressure readings
« Reply #1 on: June 08, 2019, 04:01:41 AM »
Looks like a Fine Offset clone.  You should check the Ambient/Fine Offset forum.
