Author Topic: Wunderground searchable data table on my website?  (Read 4254 times)
Offline m77
« on: January 25, 2010, 12:48:44 PM »
How do I get the searchable table onto my website?
I know how to embed the entire page but I just want the table.
Weatherlink ip, Vantage Vue,
Offline mackbig
Re: Wunderground searchable data table on my website?
« Reply #1 on: January 25, 2010, 03:25:06 PM »
Like this
http://www.mackweather.com/wxwuhistory.php
then go here
http://jcweather.us/scripts.php
Andrew
Offline m77
« Reply #2 on: January 25, 2010, 03:39:53 PM »
i am not au fait with scripts yet - plus i don't have 24.7 running pcs.
is it possible to do it another way?
that is exactly what i mean though!
Offline mackbig
« Reply #3 on: January 25, 2010, 03:48:33 PM »
Not sure about alternatives.  Dont need 24/7 weather station to have this script on your site.
This script is pretty plug and play.  Mild php (basically edit in notepad) knowledge.  and a server that does PHP
Andrew
Offline m77
« Reply #4 on: January 25, 2010, 04:03:58 PM »
Thanks, I actually meant running my pc 24.7
So I save the script in notepad and then upload it to a host.
Is that right?
Offline mackbig
« Reply #5 on: January 25, 2010, 05:52:43 PM »
Yes, that is what I meant too.
Is that right?
Pretty much. There are a bunch of variables in the main PHP file, and a readme file.  Basically you add your wu id to one of the fields, timezone, change the name of the page (defaults to Juneau County Weather, the author's locale), variable other helper variables, but do not necessarily need to be changed (metric vs imperial, show uv, etc.)  Pretty simple stuff once you open in notepad.
Then upload the saved PHP and all files as directed.  Of course as I said, the server/host you upload to must be PHP enabled.
Andrew
Offline W Thomas
  • Welcome to my area!
    • Smyth-Grayson Weather
« Reply #6 on: January 26, 2010, 11:53:49 AM »
I have that page on my site also and have a question. There is a variable to allow the script to access more than one station.
it is an array type entry and I entered my old site therre and ended up with a PHP error. I was questioning whether I could delete the array part of the statement and just have it equal my old station ID KVAMARIO3 and it not return an error?
I was making these changes late last night about misnight to be exact so i didn't dabble in too many mods that would screw up the whole site at that hour :-P
Just wondering if anybody had tried that and what code they ended up using??
Thanks!
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
Offline m77
« Reply #7 on: February 13, 2010, 12:38:28 AM »
I have had a go but it looks as if something is missing.
Can anyone help please?
www.maidenerleghweather.com/WU-History.php
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
« Reply #8 on: February 13, 2010, 06:27:02 AM »
It's meant to be included in another page and there should be a test file there to show you how.
- Jim
Offline Strgazr27
  • "The Cam Man"
    • Kings Park Weather
« Reply #9 on: February 13, 2010, 08:58:05 AM »
M,
This was one of the easiest scripts to setup. Ask these guys, if I can do it ANYBODY should be able to do it  \:D/
Configuring it was also very easy. Just follow the directions in the read-me and you'll be fine.
You can see mine here: www.kingsparkweather.com/wxwuhistory.php
I JUST finished it this am. Took me about 20 minutes to do.
Bobby M.
Davis VP2 6152 w Daylight FARS - Logitech C525 and C310
WD - WDLive - GRLevel3 - Image Salsa - VVP - Startwatch
"http://www.kingsparkweather.com"
KNYKINGS7 on WU
Offline Strgazr27
  • "The Cam Man"
« Reply #10 on: February 13, 2010, 08:59:16 AM »
Try using the wxwuhistory.php page instead. See what that gives you.
Bobby M.
KNYKINGS7 on WU
Offline m77
« Reply #11 on: February 13, 2010, 10:26:12 AM »
ok the test page is
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en-US">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"/>
<link rel="stylesheet" type="text/css" href="www.maidenerleghweather.com/WU-HistoryTan.css" />
<title>Test XHTML 1.0 Strict Page for WU-History Testing</title>
</head>
<body>
<?php
include("www.maidenerleghweather.com/WU-History.php");
</body>
</html>
this is what i have so far and can't get it to do anything.
as i said my knowledge on all this is practically nothing.
should the test page be cled for in my webpage?
« Last Edit: February 13, 2010, 10:45:24 AM by m77 »
Offline m77
« Reply #12 on: February 13, 2010, 10:27:45 AM »
www.maidenerleghweather.com/wxwuhistory.php doesn't work if that's what you mean??
