Author Topic: CloudbaseCU.php issue  (Read 1875 times)
Offline mkutche
    • GosportWx.com
« on: September 08, 2016, 08:00:26 PM »
http://gosportwx.com/cloudbaseCU.php?html=1 for some reason the graphic is staying like this and it is raining out anyone have an idea on what maybe went wrong??
Mike
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
Re: CloudbaseCU.php issue
« Reply #1 on: September 08, 2016, 08:05:43 PM »
Looks like it didn't load any metar data,  the noaa server url changed in June,  did you change it in your script.?
Offline mkutche
    • GosportWx.com
« Reply #2 on: September 08, 2016, 08:06:30 PM »
No idea how?
Mike K.
Gosport, Indiana
Offline Jáchym
    • Meteotemplate
« Reply #3 on: September 08, 2016, 08:10:26 PM »
What script are you using,  who created it
Offline mkutche
    • GosportWx.com
« Reply #4 on: September 08, 2016, 08:12:07 PM »
after exploring the coding I have fixed the url :) thanks Jac!
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #5 on: September 08, 2016, 08:12:41 PM »
www.bashewa.com I think  Cloudbase.php but for Cumulus
Mike K.
Gosport, Indiana
Offline Jáchym
    • Meteotemplate
« Reply #6 on: September 08, 2016, 08:14:01 PM »
No problem,  I am glad it works now
Offline PaulMy
« Reply #7 on: September 08, 2016, 08:24:23 PM »
I also use the cloudbaseCU script modified by BCJKiwi for Cumulus.
The code in the cloudbaseCU.php is
   if ($reload) { // download METAR as existing file is stale or missing
      $rawfile = 'http://weather.noaa.gov/pub/data/observations/metar/stations/' . $icao . '.TXT';
and that link is no longer valid.
@mkutche, I could contact Brian the script author but what did you change that to?
Offline Jáchym
    • Meteotemplate
« Reply #8 on: September 08, 2016, 08:34:42 PM »
Offline PaulMy
« Reply #9 on: September 08, 2016, 11:10:47 PM »
Thanks Jachym,
I have changed the link to the one you provided and seems to be working correctly.
Offline BCJKiwi
    • Silver Acorn Weather - N.Z.
« Reply #10 on: September 09, 2016, 04:49:26 PM »
A Notification was placed in May 2016 here http://silveracorn.nz/weather/wxscripts.php advising what to change in the cloudbaseCU script.
At the same time this was notified on the Cumulus forum here http://sandaysoft.com/forum/viewtopic.php?f=25&t=10414&start=135 when Ken True advised the NOAA change was coming.
Offline mkutche
    • GosportWx.com
« Reply #11 on: September 29, 2019, 09:21:22 AM »
old post but does anyone kno how to fix the METAR issue on cloudbaseCU.php that GODaddy is having with the get-metar-conditions-inc.php?? Metar Conditions show few clouds but CloudbaseCU is saying clear when its not clear out.. please help!!!!
Mike
even if i change $getMetar from false to true it still isn't correct.
« Last Edit: September 29, 2019, 09:23:05 AM by mkutche »
Mike K.
Gosport, Indiana
Offline BCJKiwi
« Reply #12 on: September 29, 2019, 04:52:27 PM »
It is a long time since I last looked at this script.
If you have set $getmetar = false;
then                   // if set to false will Use Cumulus (Zambretti Forecast) data ONLY
applies. The Zambretti forecast is produced by Cumulus itself and there will be no interaction attempted with NOAA.
However, you should be aware that the Zambretti forecast is very simplistic and unreliable.
Also, you would need to set ( i.e. tick the box for ) the Cumulus option
[] Use Cumulus forecast
Use the Zambretti forecast generated by Cumulus
This is under Settings / Station Settings / Forecast.
