Author Topic: [CLOSED] Alternative Dashboard Version 6.81 Released!  (Read 60302 times)
Offline RickNY
    • College Hills Weather - Farmingville, NY
Re: Alternative Dashboard Version 6.81 Released! (Minor ver 6.83 available too)
« Reply #325 on: October 14, 2013, 05:47:15 PM »
FWIW, I'm not seeing the problems you guys are showing when looking at my site under Safari/iOS 7.0.2/iPhone 5s. Also, I am not seeing the problem on Scott's site. Everything is as it should be.
Give it enough AJAX refreshes (usually within 10).. Here's yours... You'll see it eventually.  FWIW -- it happens on the iOS Simulator within the Apple iOS 7 SDK as well.
Rick
Offline jgillett
  • Boltek, Win7 Pro, ToA
    • TiggrWeather Phoenix
« Reply #326 on: October 14, 2013, 06:41:57 PM »
Interesting, Rick. Actually gave it more time than that. Will try again.
W7JKG
Offline Jumpin Joe
    • Joe’s Weather
« Reply #327 on: October 14, 2013, 08:29:22 PM »
John,  your site acts just like mine looking at in with my iPad.
https://joesweather.info
WeatherLink Live
Offline jgillett
« Reply #328 on: October 14, 2013, 08:31:28 PM »
Reset maxupdates from 100 (default) to 0 (unlimited - now reset back to 100). Let Safari pound at my site for over an hour. Not one single failure anywhere.
Sorry, but my take would lean more towards an incompatible app that might be running in the background, or possibly a setting - for me, it woiks just fine!
W7JKG
Offline Jumpin Joe
    • Joe’s Weather
« Reply #329 on: October 14, 2013, 08:39:20 PM »
Have you looked at my site? Does my site act up?
Joe
WeatherLink Live
Offline RickNY
« Reply #330 on: October 14, 2013, 09:17:10 PM »
John,
Im not sure why you dont see it yourself.. Do you see it on my site?  http://www.indigopc.com
As you see, below is another shot of your site -- this time from Apple's iOS simulator, simulating a 4" iPhone running 7.0 in a factory condition.. As you can see, it happens there too.
Again - I believe this to be an Apple issue within Safari on iOS 7 -- NOT a problem with the scripts.
Rick
Offline jgillett
« Reply #331 on: October 14, 2013, 11:09:38 PM »
Rick and Joe,
Was on each of your sites for ~20 minutes. Saw NO errors of any kind on either.
I remain - as always - confused.   ](*,)
W7JKG
Offline jonnyj771
    • Lightning Weather
« Reply #332 on: October 14, 2013, 11:43:27 PM »
Ok all, I'm probably asking in the wrong section, but since my alt-dashboard can't seem to get the FWI icons to show up;
I have noticed some that have new FWI/CBI icons. I have searched over and over and can't find them.  ](*,)
Does someone have a clue of where they are located or can post them so I can update my icons?
Facebook:
Lightning Weather
   www.facebook.com/lightningweather
                             /groups/lightningweather
Lightning Weather Quad Cities
                             /lightningwxqc
                             /groups/lightningWXQC
Weather Station Hardware: Davis Vantage Pro2 6152
Weather Station Software: WD - 10.37S Build XXX (Beta)
Page Template: MeteoTemplate v1x. (Current Active)
Offline cospringswx
    • Colorado Springs Weather
« Reply #333 on: October 14, 2013, 11:55:23 PM »
These?
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline jonnyj771
    • Lightning Weather
« Reply #334 on: October 15, 2013, 12:13:58 AM »
These?
[/quote]
no, there are newer ones out. I've noticed Scott has them on his page
Facebook:
Lightning Weather
                             /lightningwxqc
Offline gwwilk
  • Southeast Lincoln Weather
« Reply #335 on: October 15, 2013, 12:53:36 AM »
The icons are still generously provided by Bashewa on his site.  This is the relevant section from his ajaxWDwx.js script:
| ICON & GRAPHIC DOWNLOADS:        |
| ... unzip in root folder with "use folder names" when unziping                             |
| All of the below icons  :  http://www.bashewa.com/downloads/bws-iconsets.zip        (2.5mb)|
| Current conditions icons:  http://www.bashewa.com/downloads/bws-icons-current.zip   (269kb)|
|            Forcast icons:  http://www.bashewa.com/downloads/bws-icons-forecast.zip  (1.1mb)|
|  Sun/Moon bg, Moon ph x4:  http://www.bashewa.com/downloads/bws-icons-moonphase.zip ( 19kb)|
|        Moon pictures x28:  http://www.bashewa.com/downloads/bws-icons-moon.zip      (188kb)|
|       Fire Weather Index:  http://www.bashewa.com/downloads/bws-icons-fire.zip      (291kb)|
|                 UV icons:  http://www.bashewa.com/downloads/bws-icons-uv.zip        ( 20kb)|
|          Wind Rose icons:  http://www.bashewa.com/downloads/bws-icons-wind.zip      (822kb)|
I downloaded  his FWI icons in April.  It is now 363 KB in size and contains 10 icon sets.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline Jumpin Joe
    • Joe’s Weather
« Reply #336 on: October 15, 2013, 10:56:13 PM »
Rick and Joe,
Very strange. The tech support people at Apple could see it. When they switched to the previous version and viewed my site it was fine.
WeatherLink Live
Offline jgillett
« Reply #337 on: October 16, 2013, 01:25:00 AM »
Rick and Joe,
No idea what to tell you, Joe. Did what I said on all 3 sites and no errors were seen. Makes no sense...
W7JKG
Offline RickNY
« Reply #338 on: October 16, 2013, 07:40:01 AM »
John,
Strange indeed. Just to be clear, the erroneous values show up for 3-5 AJAX updates and then revert. So you only see them for about 15-20 seconds until the normal values return. They don't stay that way the entire time. Just randomly appear for a few seconds and disappear before reappearing again for a couple of refreshes.
Rick
Offline jgillett
« Reply #339 on: October 16, 2013, 11:13:27 AM »
Rick,
Understood. I did keep a close eye on he screen for the initial time period, and then just stretched it out (still watching) to see if anything happened later. All clean - but definitely not clear! Don't see how I could have missed it on all 3 sites.
W7JKG
Offline RickNY
« Reply #340 on: October 16, 2013, 12:12:04 PM »
John,
I took the liberty of making a YouTube video of the behavior using the iOS Simulator, switching between iOS 6.1 and iOS 7.  I'm on iOS 7.0.2 on my phone and iPad, and it still occurs on that version.. The simulator is running 7.0.
http://www.youtube.com/v/i6iUyB-N1TQ?version=3&hl=en_US
Best viewed in fullscreen..
Rick
Offline gwwilk
« Reply #341 on: October 16, 2013, 01:17:22 PM »
John,
Rick
I see the behavior you're concerned about, Rick.  The outrageous values are ajax updated via ajaxWDwx3.js, and it might be this JavaScript bit that iOS7 is choking on for some reason.  Since it is only seen with this OS version it has to be a bug in the OS, OR LESS LIKELY it could unmask a bug in the ajax JavaScript.  If it were the latter case things should break in a similar fashion with other browsers on other OS's.
I can't reproduce it here in Win7 on Chrome, FF, IE, or Safari while viewing Scott's, John's and my sites (which are all running the same code base).  A JavaScript console probably wouldn't help since JS keeps right on chugging away and apparently throws no errors.
I suspect this one is for Apple to fix.
gwwilk@gmail.com
Offline Jumpin Joe
    • Joe’s Weather
« Reply #342 on: October 16, 2013, 02:15:15 PM »
John,
Rick
Rick, thanks for sharing.... Now, what do you think our chances are of Apple doing something about it?  When I talked to them, they said it was not their problem, even after verifying that it was happening on iOS7 and no other version.
Joe
WeatherLink Live
Offline jgillett
« Reply #343 on: October 16, 2013, 02:50:58 PM »
Nicely done, Rick. Thanks.
First - I did not disbelieve what you guys were saying, but simply that I could not see it here. Unfortunately I wouldn't put much hope in Apple doing anything about it - they'll likely blame the 'third-party app' regardless.
Jerry brings up another interesting left-field possibility. Just for grins, I'm running v3.04 dated 15-SEP-2013. Just curious.
OK, lessee here - 9:31 viewing time, discounted rates for friends - - - $3,427.17 should do it for me...   :roll:
W7JKG
Offline Jumpin Joe
    • Joe’s Weather
« Reply #344 on: October 16, 2013, 04:03:17 PM »
FUNNY!!
WeatherLink Live
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
« Reply #345 on: October 16, 2013, 04:43:52 PM »
I also see no issues with my Motorola Razr MAXX HD smart phone using Droid version 4.1.2 with Chrome.  So it must be an Apple OS version issue....
--Stan Y.
   Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline jgillett
« Reply #346 on: October 16, 2013, 07:26:36 PM »
Rick, I went on your site again shortly after I posted my invoice. Spent about 10 minutes and did not take my eyes off the screen for even a second. Nothing...
Please pass the Excedrin!
W7JKG
Offline andro700
  • Chuck
    • Gobles Weather Page
« Reply #347 on: October 17, 2013, 09:40:55 PM »
Finally got my dashboard up and running. Found a new version of the ajaxWDwx.js script. The version is 3.02 dated 07-APR-2013.
Offline BurnsvilleWeather
  • Burnsville, MN USA
  • Retired from Weather!
« Reply #348 on: October 20, 2013, 06:42:16 PM »
UPDATE:  Beta 1 failed internationally with the date.  I believe I have figured out the problem and Beta 2 is now out to the international beta testers I have.  I should know tomorrow (Wednesday October 23rd) if it works for all!
At the risk of starting something again....
My new beta of version 6.90 hopefully now handles the dates that are stored to testtags.php in your native language and should now display correctly in the format you choose on my alternative dashboard.  I have sent several copies to those who were testing it already and hopefully they will confirm it works internationally!  If so, I will hopefully post it soon.  I've also added by request the option to show the date in 12-25-2013 and 25-12-2013 formats.
The new update will translate month names in the following languages:
English, Danish, Dutch, Finnish, French, German, German (Swiss), Italian, Norwegian, Polish, Spanish, Swedish
Its setup so you could add more languages to the script easily but it's done in the main script not the config do to some issues with how strings are passed to functions.  If I missed a language you think needs to be there please tell me and send me the three character names for each month and I'll add it.
Scott.
« Last Edit: October 22, 2013, 08:54:34 PM by BurnsvilleWeather »
www.BurnsvilleWeatherLIVE.com (Formally Webster Weather LIVE)
Home of the Alternative Dashboard and Mobile Dashboard Scripts. Weather Display Scripts and Graphics
Davis VP2 with, UV, Solar, Leaf, Web Cam.
« Reply #349 on: October 24, 2013, 04:20:44 PM »
Version 6.90 is now working and will be released this weekend.  At that time I will stop supporting the older versions.  Watch for an announcement Saturday or Sunday.
Next up is an update to the mobile dashboard!
Scott
