Author Topic: Blue Hard Reset  (Read 1313 times)
Offline cpelectronics
Blue Hard Reset
« on: July 06, 2016, 11:30:08 PM »
Is there any way to factory reset without being able to get into the web interface.  Cant connect to router, think its settings from last router.
Adam
Station 1524
Re: Blue Hard Reset
« Reply #1 on: July 07, 2016, 08:50:10 AM »
I answered this on sferics.us, but the advice is the same. Use Angry IP scanner to hunt for the IP address. Then you can point the browser to it and reset the IP address. Hopefully it is still on a 192.168.1.x address range.
Offline Joel
    • PWS Lobbes
Re: Blue Hard Reset
« Reply #2 on: July 12, 2016, 03:05:24 AM »
You also asked the same question on blitzortung.org forum
Please find below the answer from Tobi :
Reset to factory settings is possible via button:
Shortly after pressing RESET, press one of the other buttons and hold it for about 10 seconds. I don't have a station right here for testing, just try which is the correct button. Angel I think you should also hear a beep after erasing of the settings has been done. In case you don't wait long enough, only debug mode (slow!) gets enabled which outputs a lot of text over USB/serial.
