Author Topic: Weather Underground web cam  (Read 1038 times)
Offline Coosweather
« on: June 03, 2018, 11:28:40 PM »
After moving I finally got to setup my Weatherflow station complete with the “Sky” module. Quite excited at that. My downfall is that my webcam that I purchased specifically for this will only allow me to ftp upload a minimum 10Mb file when the weather underground will only accept a 150Kb file.
Not quite sure where to go from here. I would surely like a place to aggregate this information for visiting friends.
I would appreciate any suggestions.
Offline bchwdlks
Re: Weather Underground web cam
« Reply #1 on: June 04, 2018, 01:31:56 PM »
  • Send your webcam image to a machine on your home network.
  • Use ImageMagick to adjust the image to size you want.
  • Use the 'ftp' option to send the new file to Weather Underground.
You can also use ImageMagick to overlay weather data onto the image.
Offline Coosweather
« Reply #2 on: June 04, 2018, 05:10:43 PM »
You’re the best!
« Reply #3 on: July 21, 2018, 11:03:19 AM »
bchwdlks,
Well that ImageMagick seems pretty impressive. What method are you using to populate the current weather conditions? I understand you are saying ImageMagick can do this but thought maybe a bit of guidance would help instead of having to learn all the complexities of the program by myself.
Offline bchwdlks
« Reply #4 on: July 22, 2018, 03:29:34 PM »
bchwdlks,
The imagemagick writes the data to the photo, but you have to provide the data as a command line option to the convert program. I have a RPi managing the 2 web cameras, so I am using a shell script (attached as a zip) on that to:
1) adjust the image size  &overlay the weather information
2) ftp the file to WU
3) save a copy into an archive.
The weather data that I use is generated from a Meteobridge 'ftp event service'. Every 5 minutes the Meteobridge updates a file on the RPi. If you are using Meteobridge, there is a builtin section that performs a similar function.
The imagemagick line that does the work is:
convert WU_jpeg.jpg  -fill GRAY  -draw "fill-opacity 0.35 rectangle 300 0 1715 60" -pointsize 24  -fill ${COL_CODE}  -draw "text 310 25 '                                                               ${DAY} ${DATE} ${TIME}
 ===${TEMP} ${BARO} ${HUMI} ${WIND} ${GUST} ${RAIN}  ${RATE}===" -crop 1384x776+300+0 ReAdjusted_WebCam.jpg
That command is a single line with a line feed in the middle of the 'text 310 25' section to make 2 data lines on the photo.
It the script, the COL_CODE changes the text font between a light color for night and dark for day. I am using the Meteobridge sunrise/sunset data to flip between them.
« Reply #5 on: July 22, 2018, 04:44:37 PM »
bchwdlks,
That was tremendously helpful. I do have a Meteobridge. Thank you so much.
