Author Topic: Arrrrggg FTP uploads just quit working  (Read 1328 times)
Offline Mtn_man
    • Sunset Mountain Weather
« on: April 18, 2016, 08:58:20 PM »
Running WD 37R build 81, since newer versions refuse to run on Server 2008.  Been running flawlessly for a long time.  Website is running Leuven-Template 2.7, also without any issues.
At 5:30 AM this morning (I was sound asleep) FTP uploads stopped working, or at least  updating the files on my hosting site.  Some logs make it appear that everything is uploading, shows amount of data uploaded, etc., yet the files on the site are not updated (verified using Filezilla).  ftpfulllog.txt shows:
Logging onto FTP server....sunset-weather.com
Connecting to FTP server.
OK ->74.208.89.55
Connected.
220 FTP Server ready.
USER=****
331 Password required for u******26
PASSWORD=****
230 User u******26 logged in
TYPE I
200 Type set to I
Checking for next FTP agenda....
there are 2 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PORT 192,168,1,3,249,203
200 PORT command successful.
STOR index.htmltemp
425 Can't open data connection.
141: 425 Can't open data connection.
PORT 192,168,1,3,249,205
STOR indexgraph.giftemp
PORT 192,168,1,3,249,253
STOR sunset-weatherdial.giftemp
PORT 192,168,1,3,250,42
STOR cloudheight.giftemp
PORT 192,168,1,3,250,44
STOR curr24hourgraph.giftemp
PORT 192,168,1,3,250,45
STOR curr48hourgraph.giftemp
PORT 192,168,1,3,250,46
STOR curr72hourgraph.giftemp
PORT 192,168,1,3,250,48
STOR summary.giftemp
PORT 192,168,1,3,250,49
STOR signaturebanner.giftemp
PORT 192,168,1,3,250,51
STOR tagsWD.txttemp
Overall time out
301: Interrupted.
PORT 192,168,1,3,250,93
301: Interrupted.
No more files to upload
All Agenda complete, doing FTP log off....
FTP logoff
QUIT
OK ->74.208.89.55
Disconnected.
Doing abort procedure/program close...
Yet if I login and upload files using an FTPclient (Filezilla) uploads work and the files are actually updates.
What happened, and more importantly how do I resolve.
Offline ALITTLEweird1
  • Mark
    • North Bend Weather
Re: Arrrrggg FTP uploads just quit working
« Reply #1 on: April 18, 2016, 10:42:58 PM »
Who's your host?
Software: WeatherDisplay
Offline Mtn_man
« Reply #2 on: April 18, 2016, 10:49:16 PM »
1and1
  • Mark
« Reply #3 on: April 19, 2016, 12:37:21 AM »
That's who i use too. I've had issues with them before blocking my ip and need to call them to unblock it.
Offline W3DRM
    • Emmett Weather
« Reply #4 on: April 20, 2016, 12:17:34 PM »
Interesting, I had the same problem yesterday with Image Salsa not being able to complete a FTP Push operation. I am also using 1and1. Regular website access is normal as are FileZilla file activities. Only the FTP Push with Image Salsa was failing. I noticed the problem sometime early yesterday morning (April 19th). I played with it last night but couldn't get it to work. Decided to get some sleep and work on it this morning. Sometime during the night, it recovered itself and is now working just fine. Can't explain why it was failing but it was a process that has worked flawlessly for years. I have had an occasional issue with 1and1 locking out my access due to having too many connections open at the same time but not for over a year now.
--- RIPE Atlas Probe - 32849
