Author Topic: PHP script - Get the latest BloomSky image  (Read 19523 times)
Offline Bob3rd
Re: PHP script - Get the latest BloomSky image
« Reply #25 on: March 05, 2016, 11:50:48 AM »
Oh.  I am so sorry.  I'll have to find a plain text editor for my Mac.  My apologies.
Offline Bob3rd
« Reply #26 on: March 05, 2016, 12:38:53 PM »
It does appear that the .htaccess file in my public_html folder is configured for a local Wordpress instance which I use for my web site.  I will contact my hosting service to find a work around so I can run PHP files.  Thanks for your patience and help.
Offline Maumelle Weather
    • Maumelle Weather
« Reply #27 on: March 05, 2016, 01:15:59 PM »
Hi Jachym,
Works just fine here.
Thanks for taking the time to create this.
GR2AE, GR3, Cumulus
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #28 on: March 05, 2016, 01:53:52 PM »
Great :-) At least for someone it works :D
OT: John is your website down? It throws a server error when I click the link in your profile
    • Maumelle Weather
« Reply #29 on: March 05, 2016, 02:12:34 PM »
Website isn't down. I may need to change the URL. Started using Cloudflare yesterday. Hang on a sec.
Please try again. Working for me.
GR2AE, GR3, Cumulus
Offline Jáchym
    • Meteotemplate
« Reply #30 on: March 05, 2016, 05:10:58 PM »
 \:D/
Offline Bob3rd
« Reply #31 on: March 07, 2016, 02:38:51 PM »
Hi Jachym,
Did a little follow up and found that if I place a simple hello script in my public_html folder and call it with http://www.bbbrown.com/Bloomsky/hello.php I get a 404 error.  If I call it with http://bbbrown.com/Bloomsky/hello.php I get the proper response.  Having done that I then called the latest image using your script with http://bbbrown.com/Bloomsky/bloomSkyLatest.php I get a "unable to display the image "http://bbbrown.com/Bloomsky/bloomSkyLatest.php" cannot be displayed because it contains errors.  I think this is progress.  What do you think?
Also, you can see the PHP configuration of my server at http://bbbrown.com/phpinfo.php
« Last Edit: March 08, 2016, 10:18:57 AM by Bob3rd »
Offline chrisgrainger
    • Top of The Rideau
« Reply #32 on: March 07, 2016, 04:03:31 PM »
Hi Jachym,
Thanks very much for the BloomSky latest image script.  Working fine here.  http://www.rideauwx.info/wxLatestBloomsky.php
Cheers!
Chris
Offline Bob3rd
« Reply #33 on: March 14, 2016, 03:23:04 PM »
I have not resolved my issue but I have been able to run the script that retrieves the latest image enough to get an error about the image. The URL http://bbbrown.com/Bloomsky/bloomSkyLatest.php returns an error image.
The error above continues with ....because it contains errors.
So, the script seems to be running correctly. I have checked my API key for the weather station and it is correct. Other people are able to run the script using their key and they are successful.  Any ideas?
Here's the code:
<?php
// get the latest BloomSky Image file
// fill in your API key and point your image src to this file
// Jachym, meteotemplate.com
header('Content-type: image/png');
ini_set("include_path"'/home/bbbrow5/php:' ini_get("include_path")  );
$APIkey "seCtg8zXqubZrNtntrHF2c0="// your API key
$url "https://api.bloomsky.com/api/skydata";
$opts = array(
'http'=>array(
'method'=>"GET",
'header'=>"Authorization: ".$APIkey."\r\n"
$context stream_context_create($opts);
$file file_get_contents($urlfalse$context);
$data json_decode($filetrue);
$imageURL $data[0]['Data']['ImageURL'];
echo file_get_contents(  $imageURL );
« Last Edit: March 14, 2016, 03:28:30 PM by Bob3rd »
Offline VaJim
« Reply #34 on: March 14, 2016, 07:04:34 PM »
Hi guys,
I have seen several people already asking about how to get the latest BloomSky image. Since it is a dynamic URL it is not as easy, so I created a little script which will do it for you.
Instructions:
1. Download the attached PHP file
2. Open the file in a text editor and insert your API key - if you don't have one, you need to get one for free from the official BloomSky developer's site
3. Upload the file anywhere on your server
4. For the image source on your page, use this php file.
eg:
<img src="...../bloomSkyLatest.php">
It should work, but since I cannot test properly because I dont have the camera, I would appreciate if someone could confirm it.
Enjoy
Nice work!
I only wish you were around back in the day when I pushed my data to my weather page.
Thanks for helping.
Offline Jáchym
    • Meteotemplate
« Reply #35 on: March 14, 2016, 07:10:06 PM »
Hi guys,
Instructions:
eg:
Enjoy
Nice work!
Thanks for helping.
Bob3rd:
The only other thing I can think of is that there is some kind of firewall installed on your server which restricts the script from connecting to the BloomSky Api
Offline Bob3rd
« Reply #36 on: March 14, 2016, 07:23:59 PM »
I'm trying to discover the problem with my provider.  If we figure it out I will post here.  It has to do with the image.  The script runs.  So, there must be some restriction on retrieving the image.
Offline Bob3rd
« Reply #37 on: March 14, 2016, 08:28:44 PM »
Problem solved.  Turned out to be the version of PHP running on my server.  I changed from 5.3 to 5.5 and everything works now.
Offline Jáchym
    • Meteotemplate
« Reply #38 on: March 14, 2016, 08:50:16 PM »
 \:D/
Offline thewxobserver
  • Chester, Virginia
  • "Covering the weather one story at a time"
    • RVA Weather Network
« Reply #39 on: March 19, 2016, 02:41:55 PM »
Thanks for the script it has solved a problem of pulling the latest image for the website I am working on. Just a quick question is there a way to pull the image with the weather data from bloomsky on top?
Acurite Station / CWOP D0015 / WU KVACHEST36
Twitter @thewxobserver
RVA Weather Network
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #40 on: March 22, 2016, 10:01:05 PM »
The data that is over-layed on the image is pulled from the Api.
There is a simple website template posted here showing how it's done.
http://www.wxforum.net/index.php?topic=28635.0
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
  • Weather Hobbyist
    • Spring Hill
« Reply #41 on: March 22, 2016, 10:02:26 PM »
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline kirklabs
« Reply #42 on: March 30, 2016, 11:10:22 PM »
Hey there Jachym (or anyone else who sees this) - noob question here...
Thanks for providing this!! I got the script installed and a link to the php image works fine (as in http://www.kirklabs.com/weather/smartphone/icons/bloomSkyLatest.php )
WeatherUnderground wants me to either ftp an image file or link to the URL of an image file for purposes of displaying a webcam image. It will not accept a link to a php file. I am not a developer so I might be missing something, but in the example above, how would I get a link to the actual .png image file?
JD
Offline hankster
    • NFM Weather
« Reply #43 on: March 30, 2016, 11:29:22 PM »
Use FTP, the Bloomsky is already setup to do that.
« Reply #44 on: March 30, 2016, 11:46:13 PM »
Offline Jáchym
    • Meteotemplate
« Reply #45 on: March 31, 2016, 05:00:55 AM »
Use the method suggested above. As far as I know there is no other way. The way this works is that in PHP you can set the headers, which define what sort of file type it will look like to the browser. So in the above script, you set the headers to JPG or PNG and the browser then things it is an image even though it is in fact a PHP script, which creates the image. The problem is however, that if you give it the png extension it will automatically be treated as an image, the server will not try to execute it and run the code, it will simply use the actual code as image data, which wouldn´t work.
  • Weather Hobbyist
    • Spring Hill
« Reply #46 on: March 31, 2016, 12:44:37 PM »
JD
I'm almost positive I use the bloomSkyLatest.php as my image link and it works.
I'll have to double check.
Update: I checked WU and I am using the bloomSkyLatest.php file as my image and its working.
« Last Edit: April 03, 2016, 01:10:41 PM by StatenIslandWeather »
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline mkutche
    • GosportWx.com
« Reply #47 on: October 17, 2016, 06:26:27 PM »
Hi Jachym,  Thanks for sharing the script!  I have been trying to figure a way to just get the current image using web cam software and this works great!  I put your script on my web server and then using Imagesalsa I call that script to get the latest image.  From there I can manipulate the image and then upload it up to may server.  Here is the result http://weather.athelstanewi.com/wxbloom.php.  Now I can add it along with my other webcam images.  Cool stuff!
How did you add N S E W and the current timestamp?? Looks awesome
Mike K.
Gosport, Indiana
Offline ke9lz
  • De Pere - Athelstane Weather
    • De Pere Weather
« Reply #48 on: October 17, 2016, 07:13:12 PM »
Hi Mike,  I use Imagesalsa to download the picture, add the N S E W as well as the time stamp and then upload it to the server.  It's to bad Imagesalsa is outdated and hasn't kept up with the times but in it's day it was I think the best webcam software out there.  You can still download it and it's free now at http://www.imagesalsa.com/.
Steve (KE9LZ)
Athelstane Weather
Blitzortung 1177, 1565
Offline vnephologist
    • Weather Underground PWS
« Reply #49 on: May 03, 2017, 09:53:52 PM »
Jáchym, I'm thinking of hosting the script on my Meteobridge and then pointing the webcam image upload config url to localhost. I'm pretty sure the Meteobridge url parameter is expecting only an image to be returned, not html with an image. Planning to work on this soon. Any tips? Thanks!
