Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
You probably could as long as they have the same output.Solar:I/O SpecificationsGreen wire. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Output (0 to +3VDC); 1.67 mV per W/m2Red & Black wires . . . . . . . . . . . . . . . . . . . . . . . . . . GroundYellow wire . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +3 VDC ±10%; 1mA (typical)Temperature Coefficient . . . . . . . . . . . . . . . . . . . . . . . . . +0.067% per °F (+ 0.12% per °C)UV:I/O SpecsGreen wire. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Output (0 to 2.5VDC); 150 mV per UV Index, 364 mV per MED/hourBlack & Red wires . . . . . . . . . . . . . . . . . . . . . . . . . . GroundYellow wire . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +3V ±10%, 2.4 mA
