Author Topic: Minimal station with only outside temp and hum.  (Read 1117 times)
Offline droiddk
« on: February 15, 2017, 05:14:34 PM »
Hi all
Living in the city (flat) so a full packed weather station is not an option so what I’m looking for is a (minimal) weather station with an outdoor sensor (temp/hum) and an indoor unit (maybe with display and inside temp/hum). Maybe a second outdoor sensor as an option later. I would like to collect the data from the unit so it needs to be accessible in some way (wifi or wired lan would be great). And also, the outdoor unit need to be small, I only have a few bricks to install it on  :grin:
Any suggestions?
Kind Regards
« Last Edit: February 15, 2017, 05:25:24 PM by droiddk »
Offline droiddk
Re: Minimal station with only outside temp and hum.
« Reply #3 on: February 15, 2017, 06:09:44 PM »
Thanks for your reply, I will have a look at it.
And oohh I forgot, place is Denmark so wireless sensors needs to suit that.
Regards
Offline droiddk
« Reply #4 on: February 18, 2017, 02:36:07 PM »
This turns out to be quite difficult since 915Mhz is not allow in Denmark. Fx the "IP Observer" is not an option.
Offline waiukuweather
« Reply #5 on: February 18, 2017, 02:41:35 PM »
there are versions of the WiFi pro station with different frequencies
Offline droiddk
« Reply #6 on: February 18, 2017, 02:42:36 PM »
Yes like the Pro2, but then it wont be a minimal station, or what did you have in mind?
Regards
« Reply #7 on: February 18, 2017, 02:52:36 PM »
you said fix the IP observer is not an option
I thought you meant the freq used for the WiFI pro station
which you can get in different frequencies
Offline droiddk
« Reply #8 on: February 18, 2017, 02:56:10 PM »
Sorry I dont understand you. fx = for example.
"WiFI pro station" is that the name of a certain weather station?
Or, can you point in in the direction for the IP observer with 433mhz?
Regards
