Author Topic: WMR200 External Antenna  (Read 18556 times)
Offline jonkjon
    • K2mm Weather
Re: WMR200 External Antenna
« Reply #25 on: January 12, 2011, 07:59:09 PM »
Update 2............
WooooHoooo! Two full days and not a single drop!  :grin:
I think this time it's for real! Thanks to everyone for all of the help with this! I can't tell you how nice it is to be in the same room with the console and not hear that dreadful "beep" when a sensor would go....and for me, that used to happen a couple of times an hour!
Offline jonkjon
    • K2mm Weather
« Reply #26 on: January 20, 2011, 10:06:13 PM »
Just a quick (and probably last) follow up, the antenna mod is a huge success! One week later and not one single miss. If you have a wmr200 and are having reception issues, do the mod!
Offline walberg
« Reply #27 on: June 01, 2013, 12:33:10 PM »
I have the wmr88,  ik want to do the same!  place an external antenna to my wmr88  just 5 meters away from the anemometer and only 1 window between the sensors and the console and i have no signal here.  But how to open the console of the wmr88?
Offline jackal
« Reply #28 on: June 19, 2013, 10:49:00 PM »
Seeing as this post has been revived. What would a 2.4GHZ antenna do connected the the sma. Would it damage the unit or just not work correctly?
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #29 on: June 20, 2013, 12:29:45 AM »
You probably wouldn't gain much, if any, performance using a 2.4Ghz antenna on a 433Mhz receiver. You would be better off  cutting a piece of stiff wire to 173mm (1/4λ) and connecting that in.
« Last Edit: June 20, 2013, 01:39:27 AM by DanS »
Offline jackal
« Reply #30 on: June 20, 2013, 01:27:49 AM »
Thanks for the reply. I will set this up over the weekend and report back.
Offline Lloyd
« Reply #31 on: June 23, 2013, 06:33:57 AM »
Try this thread: http://www.wxforum.net/index.php?topic=18746.0
Helped me open mine and I have now added an external connector.
Lloyd
Offline FJ40
« Reply #32 on: July 20, 2013, 11:54:49 AM »
I have anywhereweather station and sensors sometimes dont report for 30 min not the shorter 5 min interval.  I have tested the sensor 5 feet from receiver so don't think this would help or would it for some strange reason?
Offline Dmitry.S
« Reply #33 on: April 13, 2014, 12:07:54 PM »
Hello!
This is my version of an external antenna for WMR200.
The antenna is made up of copper wire, assembled with a screw terminal block. Antenna length is 217 cm; cable length is more than 20 meters. Installed on a mast on the roof, near the weather sensors. To connect the antenna use a BNC connector.
Station is receiving data from Wind Speed Sensor - every 14 seconds, from other sensors - every 60 seconds (documentation as specified).
