Got my STC800 via the UPS truck late today. No info, no manual, just the unit, the boom and the mounting hardware. Opened it up and - yup - battery was not connected. Hooked the battery up, and mounted it on the pole. Ran one of the cables to the wind direction/speed unit, and coiled the other one up for later use. The cable lengths on my unit are 24 inches each. Seriously thinking about making these cables longer, but for right now, I'll work with what's there.
I'm not really interested in climbing up each month to re-adjust the angle of the solar panel for maximum output, so I'll leave it set to the spring/fall angle, which places the solar panel face at 60 degrees from vertical, and facing true south. Again, this is the initial setting, so that may change as conditions warrant.
