Yes, the 6.95 alt dashboard will work with Weather-Display (ONLY) and the Saratoga templates.
To enable, you need to change Settings-weather.php from $SITE['ajaxScript'] = 'ajaxWDwx.js'; // for AJAX enabled display
to $SITE['ajaxScript'] = 'ajaxWDwx3.js'; // for AJAX enabled display
and change $SITE['ajaxDashboard'] = './ajax-dashboard.php';
to $SITE['ajaxDashboard'] = './ajax-dashboard6.php';
and make sure you've uploaded AltAjaxDashboardConfig6.php (and the other files in the 695 distribution) to your site.
Note that the alt-ajaxDashboard will ONLY work when Weather-Display is updating the site.. it will not work with the WeatherLink plugin (nor any other software plugin).
If you have a Davis system with a 'green dot' logger, VVP will not work .. it only works with the older VP1 systems, not the newer VP2 systems.
