Author Topic: WeatherLink Backup Script  (Read 1014 times)
Offline darkpenguin
    • HoosierWeather
« on: January 11, 2016, 08:50:26 PM »
I finally got around to writing a script that I can automate the backup of my WeatherLink data.  If you are interested, the script and documentation are available on my site.
http://www.hoosierweather.com/software.php
Here's the overview of the current feature set:
  • Specify a drive/folder location of your WeatherLink data that you will be backing up.
  • Specify a drive/folder that you send this backup data.
  • To organize your backups, this script will automatically create the following folder layout:
    <Drive Letter>:\YYYY\MM\DD\wlb_hhmm
  • Configure this script to keep backups for any length of time, the only limitation is the amount of available drive space.
  • Backups that are older than the configured archive interval are automatically purged.
  • Email notifications. If enabled, the script will send an email each time it is ran, indicating a successful or failed backup. Backup and drive space statistics are also included.
  • Designed with the intention of being ran as an automated task, backups can be taken at any frequency.
  • Supports Windows 7 and Server 2008, PowerShell version 2 and higher. For alert notifications, an upgrade PowerShell to Version 3 is necessary. This should work on any version of Windows with at least PowerShell version 2, but it has only been tested on these two platforms.
« Last Edit: January 11, 2016, 10:35:13 PM by darkpenguin »
Twitter:               @HoosierWeather
YouTube Channel: https://www.youtube.com/user/hoosierweather
Re: WeatherLink Backup Script
« Reply #1 on: January 11, 2016, 09:03:46 PM »
I find wx2sql far more interesting!  Keep us informed.
Offline darkpenguin
    • HoosierWeather
« Reply #2 on: January 11, 2016, 10:37:04 PM »
Good to hear, when it is ready for testing, I will post an update on it.
