Yea I know what you are saying. Don't take my frustrations personally as it is not intended that way. I really appreciate your help with this. I am on a serious time crunch and limited to how much I can work on this because come Friday I have to turn my attention to getting the Halloween and Christmas displays staged and ready for the season. So I won't have much time to get this set up and I want to have this ready for the 2008 season since it will be a new feature to the web site for 2008.
Here is my default Settings.php. Nothing has been removed or changed except for the necessary changes to make the template work. I don't see those lines you were referring to.
<?php
# A Project of TNET Services, Inc. and Saratoga-Weather.org (WD-USA template set)
# Project: Sample Included Website Design
# Module: Settings.php
# Purpose: Provides the Site Settings Used Throughout the Site
# Authors: Kevin W. Reed <kreed@tnet.com>
# TNET Services, Inc.
# Copyright: (c) 1992-2007 Copyright TNET Services, Inc.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
# This document uses Tab 4 Settings
$SITE = array();
# Automatic Info we might need
$SITE['REMOTE_ADDR'] = $_SERVER['REMOTE_ADDR'];
$SITE['REMOTE_HOST'] = $_SERVER['REMOTE_HOST'];
$SITE['WEBROOT'] = $_SERVER['DOCUMENT_ROOT'];
$SITE['REQURI'] = $_SERVER['REQUEST_URI'];
$SITE['SERVERNAME'] = $_SERVER['SERVER_NAME'];
# Sitewide configuration
$SITE['charset'] = 'ISO-8859-1'; // character set for webpages (iso-8859-1=latin)
$SITE['CSSscreen'] = './weather-screen-red-narrow.css'; // 800px design
$SITE['CSSprint'] = './weather-screen-red-narrow.css';
#$SITE['CSSscreen'] = 'weather-screen.css'; // Classic design
#$SITE['CSSprint'] = 'weather-print.css';
# Mike Challis' Theme Switch configuration
$SITE['allowThemeSwitch'] = false; // set to false to disable the the use of Theme Switcher
$SITE['CSSscreenDefault'] = 'weather-screen-red-narrow.css';
$SITE['CSSwideOrNarrowDefault'] = 'narrow'; // 'narrow' or 'wide'
$SITE['flyoutmenu'] = true; // set to false to use classic menubar.php instead
$SITE['clientrawfile'] = './clientraw.txt'; // relative FILE location of clientraw.txt
# Configurable Carterlake/WD/PHP template Site Settings
$SITE['WXtags'] = 'testtags.php'; // for testtags.php weather variables
$SITE['organ'] = 'Mesquite Christmas Weather';
$SITE['copyr'] = '© 2007-' . date("Y",time()) . ' Mesquite Christmas, Your Live Mesquite, Texas Weather';
$SITE['remote'] = "onclick=\"window.open(this.href,'_blank');return false;\"";
$SITE['tz'] = 'CST6CDT'; //NOTE: this *MUST* be set correctly to
// translate UTC times to your LOCAL time for the displays.
// http://saratoga-weather.org/timezone.txt has the list of timezone names
// pick the one that is closest to your location and put in $ourTZ like:
// $ourTZ = 'America/Los_Angeles'; // or
// $ourTZ = 'Europe/Brussels';
$SITE['location'] = 'Mesquite, Texas';
$SITE['email'] = 'mailto:webmaster@mesquitechristmas.com';
# Weather Station sensors
$SITE['UV'] = false; // set to false if no UV sensor
$SITE['SOLAR'] = false; // set to false if no Solar sensor
# Station location: latitude, longitude, cityname
$SITE['latitude'] = '32.829927'; //North=positive, South=negative decimal degrees
$SITE['longitude'] = '-96.648573'; //East=positive, West=negative decimal degrees
$SITE['cityname'] = 'Mesquite';
# USA Specific settings
$SITE['noaazone'] = 'TXZ119'; // used for NOAA advisories and advforecast2.php forecasts
$SITE['hurlURL'] = "wxadvisory.php"; // page to launch for details on NOAA advisories
#Forecast script settings area
$SITE['UVscript'] = 'get-UV-forecast-inc.php'; // worldwide forecast script for UV Index
// comment out above line to exclude UV forecast
# if you have WXSIM and plaintext-parser.php, set $SITE['WXSIM'] = true;
# to have the WXSIM forecast text appear in the dashboard along with your primary forecast org's
# forecast.
$SITE['WXSIM'] = false; // Set to false if no WXSIM/plaintext-parser.php
$SITE['WXSIMscript'] = 'plaintext-parser.php'; // script for decoding plaintext.txt into icons
# fcsturlNWS is the point-printable forecast URL from http://www.weather.gov/ (used by advforecast2.php)
$SITE['fcsturlNWS'] = 'http://forecast.weather.gov/MapClick.php?CityName=Mesquite&state=TX&site=FWD&textField1=32.769&textField2=-96.5998&TextType=2';
$SITE['fcsticonsdir'] = './forecast/images/'; // NOAA-style icons for NWS, WU, WXSIM forecast scripts
#---- in the following section, enable settings for ONE primary forecast organization
# pick which script AND org are to be used for your forecast here: (last uncommented pair will
# be the ones used on the wxforecast.php page and in your dashboard and sidebar
$SITE['fcstscript'] = 'advforecast2.php'; // USA-only NWS Forecast script
$SITE['fcstorg'] = 'NWS'; // set to 'NWS' for NOAA NWS
#$SITE['fcstscript'] = 'plaintext-parser.php'; // WXSIM forecast (if only forecast script)
#$SITE['fcstorg'] = 'WXSIM'; // set to 'WXSIM' for WXSIM forecast
# ajax-dashboard, ajax-sidebar settings (will override defaults in
# the scripts themselves when included in this site
$SITE['WDdateMDY'] = true; // for WD date format of month/day/year. =false for day/month/year
$SITE['uomTemp'] = '°F';
$SITE['uomBaro'] = ' inHg';
$SITE['uomWind'] = ' mph';
$SITE['uomRain'] = ' in';
$SITE['uomDistance'] = ' miles'; // or ' km' -- used for Wind Run display
$SITE['uomPerHour'] = '/hr';
$SITE['imagesDir'] = './ajax-images/'; // directory for ajax-images with trailing slash
# note: date format used for PHP parts only. Weather-Display dates are not processed
# except on the astronomy page
$SITE['timeFormat'] = 'D, d-M-Y g:ia T'; // Day, 31-Mar-2006 6:35pm Tz (USA Style)
//$SITE['timeFormat'] = 'm/d/Y g:ia'; // USA format 03/31/2006 14:03
//$SITE['timeFormat'] = 'd/m/Y H:i'; // Euro format 31/03/2006 14:03
//$SITE['timeFormat'] = 'Y-m-d H:i'; // ISO format 2006-03-31 14:03
$SITE['timeOnlyFormat'] = 'g:ia'; // USA format h:mm[am|pm\
#$SITE['timeOnlyFormat'] = 'H:i'; // Euro format hh:mm (hh=00..23);
$SITE['dateOnlyFormat'] = 'd-M-Y'; // for 31-Mar-2008 or 'j/n/Y' for Euro format
# carterlake-radar settings (will override defaults in
$SITE['noaaradar'] = 'FWS'; // LAST 3 characters of NOAA Radar Site ID
// e.g. Radar KMUX has $SITE['noaaradar'] = 'MUX';
$SITE['WUregion'] = 'sp'; // Wunderground regional maps
// 'sw'=SouthWest, 'nw'=NorthWest, 'mw'=Midwest
// 'sp'=South Central, 'ne'=North East, 'se'=South East
$SITE['WUname1'] = 'City Level'; // tooltip label for mode=1
$SITE['WUname2'] = 'Dallas/Fort Worth'; // tooltip label for mode=2
$SITE['WUname3'] = 'North Texas'; // tooltip label for mode=3
$SITE['WUname4'] = 'South Central'; // tooltip label for mode=4
$SITE['WUname5'] = 'Entire US'; // tooltip label for mode=5
# GRLevel3 Radar image settings
$SITE['GR3radar'] = 'kfws'; // set to lower-case full name of NEXRAD radar site
$SITE['GR3DIR'] = '/weather/GR3'; // set to directory for GRLevel3 images (or '.' for root directory
$SITE['GR3type'] = 'br'; // radar image type 'cr','br','cr248','br1' etc.
$SITE['GR3img'] = 'jpg'; // GR3 image type 'jpg' or 'png'
$SITE['GR3cnt'] = 10; // number of images in series 10=(_0 ... _9 in name of file)
$SITE['GR3width'] = 512; // width of GR3 images
$SITE['GR3height'] = 512; // height of GR3 images
$SITE['showradarstatus'] = true; // set to false to suppress 'active' message
# end of configurable settings
# set the Timezone abbreviation automatically based on $SITE['tzname'];
putenv("TZ=".$SITE['tz']);
$SITE['tzname'] = date("T",time());
if($SITE['allowThemeSwitch']) {
# begin Color Theme Switcher Plugin by Mike Challis
# http://www.carmosaic.com/weather/scripts.php
include_once('include-style-switcher.php');
$SITE['CSSscreen'] = validate_style_choice();
# end Color Theme Switcher Plugin
Now the only code I could find relating to file paths for the flyout menu was in the flyout-menu.php was this....
// ---------- settings ------------------------------
$MENUdef = './flyout-menu.php'; // (relative) file location of XML menu definition file
$MENUdefTest = 'f./lyout-menu-test.xml'; // (relative) file location of test XML menu definition file
$imagesDir = './ajax-images/'; // (relative) URL location of images dir (with trailing '/')
// ---------- end settings --------------------------
Are those the ones your are referring to?
-Thanks
